Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Water comes up into top drawer
There is standing water in the top drawer after I do a load in the bottom drawer.... any suggestions???
    Genius:
  • Fisher and P... Master
  • 1,224 Answers
Seals are worn out you most likely need to replace due to hard water or solvent break down this product is known for bad seals
Posted on Dec 06, 2008
My Frigidaire affinity washer leaks water into the washer stand. Whenever I open the drawer after washing a couple of loads there's water in the drawer.
That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
Oct 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
The water backs ups from the dispenser tray and leaks out to the floor once the machine starts to add water. LG front load model WM2487H*M. It looks as if something may be clogged in the path from the...
Remove bottom phillips head screws from plastic clip on the back of the washer's top cover. Standing in front of machine, use the palms of your hands to sharply push back on the washer's top, pushing top back about 2 inches. Lift off top.
I've had to remove the dog food that a mouse put there after the dispenser drawer was left open.
Also, remove dispenser drawer by pushing tab down at back of drawer while pulling out drawer. I've had to clean out a thick layer of fabric softener from there already on another machine also.
Feb 26, 2011 | LG WM2487HA Washer
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Significant water leaks through the bottom on the front side as soon as cycle starts. Already cleaned out the filter and hose from bottom right corner. Any suggestions? LG Model WM0532HW
Check that the door seal hasn't got a split or hole in it. Check between the bowl and the front panel. The water must be coming from somewhere. could be a hole in the outer drum itself or it could be the detergent drawer overflowing.... As a last resort... Carefully take off the top by unscrewing the screws at the rear, bump the top panel back to unclip it and VERY carefully look while the machine fills. DO NOT TOUCH as there is bare wiring...Remember water and electricity make a shocking combination!!! ....Nomess
Apr 01, 2010 | LG WM-0532HW Front Load Washer
After top drawer is run, bottom drawer has
check the check valve on bottom drawer. unplug hose drain hose off drawer underneath. a small ruber check valve can be clogged. if its good replace it
Feb 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water coming out of dispenser drawer?????
The hose from the drawer is probably clogged.
Jan 24, 2008 | Hotpoint WMA31 Front Load Washer
Leaking
check your water valve at back and your water connection.if there o k it probably is your pump.
Nov 12, 2007 | Kenmore 22422 Top Load Washer
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
111 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
