Question about HTC PPC-6800 Smartphone
I need the navigation to "align screen" for a PC 6800. Please help!
    Problem Solver:
  • 9 Answers
This was taken from the users manual......
1. Tap Start > Settings > System tab > Screen.
2. On the General tab, tap Align Screen, then follow the on-screen instructions to complete the calibration.
hope that helps.
Posted on Jan 07, 2009
Were can i get a copy of the manual for sharp pda el-6800
Please select the below link to download your manual for sharp pda el-6800.
http://www.devicemanuals.com/guide/PDA/Sharp/Sharp-Memomaster-Organizer-EL-6800-Operation-TWpVNU1qYz.html
Before downloading Please input validate code for download.
Thanks and Regards
Anand Sachan
Oct 28, 2010 | Computers & Internet
I have a gateway 9310S with a 15in monitor that
try removing 6200 completly,and then put on 6800 and instal that gpu first.....
Apr 02, 2010 | XFX GeForce 6800 GT, (256 MB) Graphic Card
My HTC Touch Diamond Screen is not working. Hellllllllllllppp THe screen seems to out of alignment but i have a security code and i cannot get oast that to re-align my phone.
Hello :
Did you try soft reset or hard reset .? If those both didn't solve the problem , then it must be a hardware failure . For hardware failure , i recommend you to replace it with new one , if you still have the guarantee .
good luck .
rate please !
Mar 18, 2010 | HTC PPC-6800 Smartphone
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Pocket PC 2003 Pro unable to align screen
the touch screen plug on the motherboard is disconnected
Sep 06, 2009 | HP Computers & Internet
My toshiba pocket pc is stuck on the pop up menu screen - I can't navigate around it.
The unit will not go past the alignment screen until it gets a good calibration alignment. Be sure to click as close to the little + marks with the stylus as you can. If the click is to far from where it thinks it should be then the alignment will fail and start over.
I hope this helps, if not let me know
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
http://www.wireless.att.com/support_static_files/manuals/ATT_Tilt.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Jun 29, 2009 | Computers & Internet
Align screen
ur Touch panel or in other word Digitizer is faulty try getting it replaced it is around 60 or 70 $ , if u dont want to spend money right now and just want to get rid of this screen alignment process just google 'bypass screen alignment ' there is a utility for that just connect ur pda using usb cable and bypass this process but u will not gett correct response when u touch the screen u will get mis aligned response if u want to get rid of this u have to spent money on hardware replacement
Feb 21, 2009 | HTC PPC-6800 Smartphone
Can anyone help me with screen alignment problems with the HTC 3450 touch
if it has windows mobile and navigation buttons use the bottons to go to: start,settings,system,screen then click align screen
Feb 20, 2009 | HTC Touch P3450 Smartphone
PC 6800 - Align Screen
start->settings->system->screen-> align screen
Dec 06, 2008 | HTC PPC-6800 Smartphone
Acer Veriton 6800 PC Desktop will only beep will not boot.
Hi Just checking first of all you have tried another memory module. This sounds like a faulty RAM. Please try and get back to me if that doesn't fix it. Thanks, Lolita
Jun 02, 2007 | Acer Veriton 6800 PC Desktop
HTC PPC-6800 Smartphone Logo
69 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
