Question about Hitachi P42H401 42 in. Plasma HDTV
No power Hi my son hit the reset button on a powerboard that my plasma was plugged into and it tripped the meter. I went and flicked the meter switch and all other equipment came back on but not the plasma...can you help? I've tried pluggin it straight into the wall. I've turned on and off the main power switch and sub power. Still no lights showing. No Power. Plugged into wall outlet, outlet is getting power. TV will not come on. Is there a reset button? Can't find manuel.
  • 4,338 Answers
I just read the user manual and it does not show a reset button. Are there any lights blinking? Let you set sit for a while and the turn it on once with the main switch. Constant switching on and off can and will cause problems.
Here is the User manual:
http://merchant.satisfusion.com/sf/library/manuals/owners/P42_50_55H401_4011.EN.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 06, 2008
    President:
  • 1,952 Answers
Tv fuse is out and fix the fuse or then change the ic
  • mohammed marika thambi
    mohammed marika thambi Dec 06, 2008
    Press the POWER
    SWITCH (ON/OFF
    SWITCH) once.
    2. If there is still no power,
    wait 30 seconds and
    press the POWER
    SWITCH again.
    3. If there is still no power,
    unplug the power cord
    from the wall. Wait 30
    seconds and plug the
    power cord back in.
    Press the POWER
    SWITCH again.
    High temperature affect the electric discharge/luminescence characteristic of the PDP
    panel. Do not place the plasma television in high temperature environments.
    Operating altitude: 700 to 1,114hPa (9,676ft to -2,484ft). Operating temperature: 41°F
    to 95°F.
    : 300 to 1,114hPa (31,912ft to -2,484ft). Storage temperature: 5°F to
    140°F
    Repeatedly turning the plasma television Power ON and OFF at short intervals may
    result in failure of the television.
    The on-screen motion of an actor's lips or other moving object may not be in sync with
    the associated audio heard from the TV's speakers. This is caused by timing differences
    in the broadcast signal or DVD content and is not caused by a defect in the television.
    There's a few seconds response delay on the control buttons (Control panel or R/C) after
    Response Delay the TV is turned ON; due to TV start-up routine. Please note that this is not a TV malfunction
    Genius:
  • 2,920 Answers
He may have accidentally shorted out the main board....its like a power surge to the tv and he may have accidentally fried the set.
How to reset oil maintenance switch
I believe it might be in manual also. Here is instructions.
Switch the display to the trip meter "A"
Turn the "POWER"switch off.
(If you have push button start)
While pressing the trip meter reset button turn the "POWER" switch to ON mode (press power button 2 times, foot off the brake).
Continue to press and hold the button until the trip meter displays "000000"and the multi-information display indicates that the reset is complete. or you here a beep.
May 17, 2014 | 2012 Lexus IS 250
How do i reset maintenance light
Insert the key into the ignition.
Press and hold the trip meter reset button. Turn the engine switch to the "on" position.
Hold the trip meter reset button until the trip meter displays "000000." The maintenance light is reset.
May 14, 2014 | 2005 Toyota RAV4
Where is the trip meter reset button on a Lexus ES350
Hi there:
  • Turn the "Engine Start Stop" switch OFF with the trip meter A reading shown.
  • While pressing the trip meter reset button, set the "Engine Start Stop" switch to the Ignition ON mode. Continue to press and hold the button until the trip meter displays 000000.
  • Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
    Thank you for using FixYa, have a nice day.
    Aug 21, 2012 | Lexus ES 350 Cars & Trucks
    Hi How do i reset my service light on my 2004
    press and hold trip meter reset button with ignition off. switch on ignition while holding button. release button when ignition is on and then turn clock setting button to the right and hold for a few seconds until service light resets.
    May 14, 2010 | 2004 Volkswagen Passat
    WON'T TURN ON.
    Powerboard damaged, if you could not see the Led light on stanby mode it means you have no power at all.
    Go ahead and replace your powerboard and your TV will be Ok
    May 28, 2009 | LG 42PC3DV 42 in. Plasma EDTV
    Brand new LG plasma stuck on test screens
    Resetting the TV
    If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
    NOTE:
    Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
    1. Unplug the TV power cord from the power outlet.
    2. Unplug any connected devices (DVD, Set-top boxes, etc...)
    3. Press and hold the TV power button for five seconds.
    4. Plug the TV power cord back into the power outlet and turn on the TV.
    5. Open the on-screen menu to confirm that the TV is responding again.
    6. Turn off the TV and reconnect the devices.
    7. Turn on the TV.
    Hope it may help you;
    Regards;
    VOTIT
    Jan 29, 2009 | Televison & Video
    No power
    it sounds like he triped the internal fuse on the tv when he surged the power
    Dec 01, 2008 | Hitachi P42H401 42 in. Plasma HDTV
    Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
    HI CHECK THESE....
    Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
    Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
    Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
    THANKS
    Sep 12, 2008 | Washing Machines
    Hitachi P42H401 42 in. Plasma HDTV Logo
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
