Question about Faberware FCP240 Coffee Maker
I need the plastic base for a Faberware FCP 240-A 4 cup Percolato
The plastic base is cracked. its the part the is attached to the main part of the coffee pot by one nut on the bottom. if you take this base off, you will have access to the heating element the temp switch and also the prongs that the electric cord plugs into.
  • Anonymous Mar 13, 2014
    Plug is ok just will not make coffee
    Genius:
  • 1,224 Answers
Ok heres a simple fix if you dont have the money for replacement or cant find parts
J.B.weld from auto parts store this stuff if strong enough to fix a cracked engine block so im sure the pot can get fixed this way
Posted on Dec 06, 2008
How much coffee do I put in a 22 cup faberware perculator
depends on how many cups of coffee you want. if you want 22 cups, suggest 1 1/2 cup of coffee.
Mar 03, 2017 | Faberware Coffee Makers & Espresso...
Looking to replace the cord insert posts on the base of a 12 cup faberware coffee pot. How do I take the base off to get to the posts? Thanks, Joe
You have a China pot. Take the center screw out of the base, Pry it apart very slowley . The pot has 2 or 3 wires that go to thee main heating element. you will need a neddle nose pliers.Detach the wires on the main unit and you will be able to work on the base. Parts are available on eBay
Jul 13, 2010 | Faberware FCP412 Coffee Maker
COFFEE POT
Hi Cynthia. I sell the base for 8.00 used and 2.00 S/H. I have to know if it is 3 wire or 2 wire. callahanronald@att.net For feedback my eBay is ron622c
Jun 14, 2010 | Faberware FCP240 Coffee Maker
How much coffee do I use for 30 cups
You must use around 7 to 8 gr per cup so you will need 210 light coffee to 240 gr for strong coffee for 30 cups.
Good Luck
Remember to vote for this answer.
Feb 28, 2010 | Faberware 12-55 Cup Coffee Urn
I have a fcp 512 and the contacts in the base are
Hi. The model # you have a 12 cup China pot.You have to replace the base. Do you use a 3 wire cord or a 2 wire cord. I have the 2 wire base, 8.00 plus 3.00 Go to eBay (ron622c) in find member. bobbyone
Nov 05, 2009 | Faberware Coffee Makers & Espresso...
Have a 2 year old farberware FCP 240 which dos not
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers. You have a pot made in China
Oct 10, 2009 | Faberware FCP280 Coffee Maker
Electric cord
You can use a computer connection cord.
Dec 20, 2007 | Faberware FCP240 Coffee Maker
Faberware FCP240 Coffee Maker Logo
204 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
