Question about Acer Aspire 5500 5570-2609 Laptop
Electricity out Hi I had a power out in my house en my aspire 5920-6864 and my computer goes out, and when I tried to turn it on does not turn on
  • 24 Answers
Sounds like a power surge. These can ruin delicate equipment. try this, Unplug laptop and remove battery for 30 minutes, Reinstall battery and plug in charger and try to start up. If it works, you're golden, if not prepare to submit an insurance claim on your homeowners policy.
Posted on Dec 06, 2008
Hi when i plug in the power cord and press the power button the power light comes on then goes off and the laptop won't start its and acer aspire 4339-2618 what can be done to fix this i try holding down...
Try removing the power cord and the battery, wait 30 seconds and then plug in the power adapter while the battery is not inserted. Then try to turn the machine on.
If this doesn't work, there is something serious wrong with the machine and it will need to be repaired by your local computer shop.
Sep 16, 2013 | Acer Aspire Computers & Internet
Laptop screen not coming on
Drain it! You might be surprised that one day as you turn your computer on, it shows no display. It can be caused by electrical charges on the motherboard, I do not specifically know how it affects the display but in case this happens to you try to do a Power Drain.
>It's easy, first, press the power button for about 5 seconds (if the indicator light for power is still lit)
>Take the battery out from the laptop
>Unplug the AC Adapter if it is connected(for desktops, unplug power cord from the CPU/tower)
>Then press and hold the power button down for at least 30 seconds.
>Plug power supply back into your system
>Turn it back on.
There goes your display once again.
Thank you for choosing FixYa! have a great day!
Apr 04, 2011 | Acer Aspire 5742Z-4200 Notebook
Hi, we moved house and plugged everything back in but now the internet goes really slow (like 1 page takes a full minute to load). ISP provider says the speed is fine to the modem, so it is some other...
Your internal telephone wiring in the new house may be the problem, you need to find the first socket from the outside that connects to your house. If you have multiple phone sockets, you may need to try each one until u get one that has good speed, usually that is the primary socket.
This is quite common in old houses where the internal wires used were cheap or may have degraded over time.
Mar 09, 2011 | Linksys AG310 ADSL2+ Gateway with VoIP -...
Hi my acer aspire 5315 will not boot up, i turn it on i get nothing but the little cursor in the top right hand corner...can anyone help please thank u in advance
That is probably because some important boot files are missing. What you can try is to take out the hard drive and move it to another acer aspire 5315 computer. To take out the hard drive, remove ALL electrical components (power cable, battery, etc.), open the computer's hard drive bay, and take it out VERY carefully. Make sure you do not cut the cables. That could damage the hard drive. Then, you remove the hard drive on the other acer aspire 5315 computer using the same instructions above. Then, you can identify the missing boot files (they will be in a hidden drive called System Reserved), copy them onto your computer's hidden System Reserved drive (if it's missing you'll have to create one manually), and put it back in the other acer aspire 5315 computer. Make sure that you put the wires where they were when you removed them, otherwise the hard drive might not work. Then, try turning on the computer again.
Nov 14, 2010 | Acer Aspire 5315 Notebook
I have Aspire 5520-5912 Notebook. When I turn on power with battery or ac adaptor, the power just comes and goes, the power button light, power indication light and HD operating indication lights just...
I m also suffering from same problem on aspire 4310. When the problem occurs, I remove the battery for an minute and insert again.... This trick have solved my problem. Try the same trick on your laptop and see that whether it works or not... Otherwise get it serviced....
Thanks...
Jun 30, 2010 | Acer Aspire 5500 5570-2609 Laptop
HP Printer Usb port in my Acer Laptop , shortcircuits my house
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Aug 26, 2009 | Acer Aspire 6930-6941 Notebook
Acer Aspire 5520
Sounds like a fried battery. Try a brand new one.
Jul 14, 2009 | Acer Aspire 5520-5579 Notebook
Acer Aspire 7520 turns off and on repeatedly
Mine does this but what I found was that if you hold the power button down for about 10 seconds when you are turning it on, it works.
Dec 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
ACER ASPIRE T180
1. Remove the memory and put it back in again.
2. Remove the video card and put it back in again.
Check those two items first. Usually a beeping at the beginning would indicate either a memory or video problem, depending on the type of beep and computer.
Thanks and please don't forget to rate as fixya. Thank you.
Jul 17, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire 5500 5570-2609 Laptop Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
