Question about Amana AOCS3040 Electric Single Oven
Dosen't Turn On Or Fires Up!!!
Every Time I Turn On My Oven, It Doesn't Fire Up And Turn On And Sometimes It Takes A Few Hours For It To Actually Turn On. What Do I Do To Fix That Big Problem?
    Genius:
  • 1,224 Answers
If gas you have clog in gas pipes if electrical you have a computer related problem that should be covered under a service warranty
Posted on Dec 06, 2008
What's causing my oven to stay hot HOURS after I've turned it off?
If you have the older type stove with the oven knob that has the temperature setting around the outside of the knob, then that part could be bad. It is called a thermostat. That part usually comes with sensor attached. The sensor is the long skinny looking tube that goes through a hole and into the oven.
If you have the newer type electronic stove where you program in the temperature you want, the electronic circuit board could be bad. But the electronic stoves have a over temperature protection built into the circuit board, so that would have engaged, shutting down the stove.
Either way, it is a potential fire hazard and needs to be addressed.
Nov 07, 2014 | Hotpoint Ovens
Takes a long time to get to temperature
If it's a gas oven and has an electric element starter (glows orange to ignite the gas), the element can be taking a long time to heat up, which means the oven doesn't light for a while and so seems to lake a long time warming up. If you turn it on and then look at the area where the flame should be (broiler) and the flame takes a long time this could be the problem. This happened to me and replacing the element fixed it. Now the flames light within 30 second or so.
Nov 11, 2012 | Ovens
How to clean the H 398B2 inside?
Hi I find that oven pride painted on the inside of the oven and left for several hours works wonders, put shelves etc in the plastic bag supplied - shake - and leave for a few hours also. This was a much better product than the lakeland version.K
Nov 19, 2011 | Ovens
My oven had flames burning up from the bottom during the self cleaning cycle. I managed to turn it off but it won't unlock. How do I unlock the door if I see flames? They stopped.
The oven wont unlock until the inside is at a certain temperature, to prevent you from burning yourself with the convective heat, or worse, the fire spreading to outside the oven. Once the flame runs out of oxygen inside, the flames will go out. But the oven may not unlock for a few hours at the most.
Mar 31, 2011 | GE Monogram® ZET958 Electric Double...
My Westinghouse 668 oven turned off in a recent power failure. I need to reset the time so the oven will work. How do I do it?
A lot of the time, particularly if you haven't got a manual, it is trial and error. I normally turn the oven to on. I then watch the oven indicator light as I manipulate the timer buttons/controls. It sometimes takes 5 to 10 minutes. Just try all different combinations.
Feb 12, 2011 | Ovens
All four burners click at the same time; Sometimes will not light
hey mate i have had this problem with my oven, they get moisture in them. Turn it off at the power point for a few hours or before you go to bed and turn it back on the next morning and it should be fine. that should get the moisture out. hope this helps. Keeno in OZ
Mar 19, 2009 | GE Ovens
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Oven takes a long time to heat up
your ignitor could be going out. the ignitor has to get hot enough in order for the gas to turn on and heat your oven. if your ignitor is going out, sometimes it doesn't glow hot enough for the gas to turn on, or it could be that is takes longer than normal to get hot enough to turn the gas on. I would replace the ignitor and that should solve the problem. Joe
Nov 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Turning off oven.
The fan only comes on in the back of the oven when convecting and Automaticaly turns off when you open the door. The exhaust fan coming from the front stays on for qutie a while, maybe 2 hours or so till the oven cools. I think it is just a function of the oven. A good thing in the winter but uses a bunch of airconditioning in the summer
Oct 23, 2007 | Electrolux ICON 30 in. Double Wall Oven
Amana AOCS3040 Electric Single Oven Logo
128 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
