Question about Dell Latitude D600 Notebook
I have a dell lattitude d610 that it wont turn on at all i already check voltage on the charger it gave me 18 volts and battery is fully charge when i plug it nothing turn on neither lights does this thing has like a fuse or something i can replace?
  • 1 more comment
  • jodha Jan 11, 2009
    As soon as my laptop is coonected to ac power the the green led of ac adapter goes off, its not even turning on with fully charged battery installed. Its so happened that I was using it on ac supply, I tried to switch on it just went off.
    Pls help me if you can, I have already opend the notebook but nothing is burnt on the system board.
    Thanx in advance
  • Dale Barrett
    Dale Barrett May 11, 2010
    Does the system start at all, or are you having a problem getting the thing to start regardless of how you try to power it?
  • Alan Matzke
    Alan Matzke May 11, 2010
    r u running this off of battery or r u using AC current?
This is not for merka65, but for jodha who said his D610 shorts out his charger. I just fixed a D610 motherboard that would short out the charger and make its green light go out. I was able to track down the problem to a shorted monolithic capacitor on the motherboard. I replaced it and the problem was solved. Prior to the fix this motherboard would run on a charged battery. Now it runs on the charger and charges the battery.
It wasn't easy to track it down without a schematic. Took about an hour or detective work with a bench power supply to force a little voltage in and look for a hot component.
I could do more component repairs if I had schematics but Dell apparently doesn't release them. Very frustrating!!!!
Posted on Feb 01, 2009
    Novelist:
  • 89 Answers
Laptops are notorious for having the adapter plug come loose from the motherboard although, most laptops will power off of the battery if this happens (if the battery has a good charge). Some laptops have a DC power board that can burn out. Or in some cases, It can be the power button bar. If you are not comfortable trying to repair it yourself, I suggest taking it to a reputable repair shop but it will probably cost you quite a bit to get it fixed. If you know someone who does this type of repair you might check with them.
Posted on Dec 06, 2008
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Have 2 lights on charger. One power, the other says charging. Both come on but after about 15 mins the charging light goes off. Does this mean the battery is charged?
so no lights go green, it depends on the charger however in my experience all of the charger i have repaired have a green light to show fully charge, is it possible to try another charger ? this could imply a faultly charger , can you check the battery voltage anywhere from 26 volts DC to 28.3 volts DC no more otherwise you shorten the life of the battery. You really want the voltage level to be near 28 volts that way you will get maximum distance as well as prolonged life of the batteries in question.
Regards
Please leave feedback.
Dec 19, 2012 | Pride Mobility Products Go-Go Elite...
My trimmer wont start. thought it was battery put a new one in worked for a few minutes and then stopped working
your batteries aren't charging fully, check them fully charged with a volt meter,, fully charged they should have a reading of 18.5 volts, if not they are not charging, and either the batteries have used up their life, or your charger is on its way out
Jul 15, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
My Dell Lattitude 610 will not power on when the power button is depressed. The battery has been switched with a battery that was fully charged, still no sign of life. What can I do?
Remove the battery and power on the laptop with the AC adapter and see if it powers up. If not then you probably need to have the motherboard replaced.
Jul 02, 2011 | Dell Lattitude D610
Charger light is on battery wont charge dell inspiron 1521
Your battery could have given up.
Check the voltage coming out of the transformer. You should have 18-19 volts.
Either that or your motherboard charging circuit could have quit.
var fctb_tool=null; function FCTB_Init_b0ce79c3f5ef4364b14d241b4dc4914c(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_a34f1cd5f89c4751adca26070525f32c(t) { fctb_tool=t; start(fctb_tool); }
Dec 22, 2010 | Dell Inspiron 1521 Notebook
Dell lattitude d610 notebook wont power up. Got new battery yesterday, worked fine. Shut it down & now it wont power back up & yes the battery is fully charged.
Take the battery out (1 screw in the bottom of the case, then it pops out with the tab) and attach the power adapter, and see if it boots up now. If it does, you have a problem with your battery.
Did you have this problem before the new battery?
Aug 11, 2010 | Dell Latitude D610 Notebook
Flashing Lights On My Computer?
You've changed the batteries, but are they fully charged?
I usually leave my charger in all the time when using the laptop as Advent laptops have bad battery life.
Try charging it for max 8hours. If the problem stil persists,then i guess its something internally wrong with the laptop?
Or even, the charger wire may be a bit loose which is preventing it from charging the laptop either completly or partly.
Hope that helped
http://stores.shop.ebay.co.uk/Sabka-Hosiery
Mar 10, 2009 | Dell Lattitude D600 Notebook
My dell lattitude D610 laptop wont charge battery
before you come to that conclusion, try it on AC power only
get back to us if the problem is still the same
regards
Dec 22, 2008 | Dell Latitude D600 Notebook
Dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Nov 26, 2008 | Dell Computers & Internet
Dell Latitude D600 Notebook Logo
312 people viewed this question
Alun Cox
