Question about Samsung DVD-R155
Samsung DVD-R155 will not play in Dolby Digital surround sound
The player will play DTS just fine, but any Dolby Digital signal is auto-detected and played by my Yamaha RX-V3000 receiver as an analog 'Pro Logic' signal. I am using the PCM options.
    Genius:
  • 1,199 Answers
You need to buy a digital coax cable Just 1 run out of player and into amp!
Posted on Dec 11, 2008
Code to change settings for Small loud speakers to large. Model No HT-F450K to HT-F455K models
Speaker size selection usually is part of receiver set up; the DVD player has nothing to do with it.
Jun 27, 2016 | Samsung HT-C650W DVD Home Theater System,...
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
HTddw670 play only 3.1
The problem sounds like it is the dvd player, have you set-up the audio output menu on the dvd players setup menu? Some dvd units default to a 2 channel stereo output, what is required is you need to enter the setuo menu and enable a dolby digital 5.1 output or the DTS/Bitsteam audio output option. Also be sure to use a digital signal cable connection.
Feb 09, 2009 | Sony HT-DDW670 System
I cannot seem to get DTS-HD master to show on the receiver screen
You need to check 3 things:
1) DTS will only work through a digital connection (coaxial, optical, or HDMI) between your receiver and dvd player. DTS and Dolby 5.1 cannot carry a signal over red and white rca connections.
2) After number 1 is solved ensure the reciever is set to the digital channel, your DTS-HD in this case, or in an auto mode.
3) Finally the most important is that the signal is a DTS signal. Start a DTS capable dvd, go to the sound menu and set it for DTS.
Press play and all should be well...
Cheers,
NTIMID8
Dec 13, 2008 | Onkyo Audio Players & Recorders
NO SURROUND SOUND WHEN PLAYING BLU-RAY
Your amplifier should "downgrade" the signal to 5.1, even if the disc isn't using it. It is most likely a setting on your amp that may need adjusting for "types" of digital to accept on its input. If you can, set your optical input on your amp to "auto". This way it will automatically detect and switch for the proper incoming audio feed
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
Yamaha rx-v595a problem with dts signal
the unit must be switched to digital in order for the auto function to work, then it will automatically select dts or dolby digital. youn need to check your digital feed from the dvd player.
Dec 28, 2007 | Yamaha RX-V595A Receiver
Toshiba HD-A30 won't play digital sound with HD DVDs
Try checking your audio output in the setup screen of dvd player. Try setting Digital Out HDMI to Auto, if it isn't already. See if that helps.
Dec 28, 2007 | Toshiba HD-A30 HD-DVD Player
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
Samsung DVD-R155 Logo
70 people viewed this question
Henry  Thomas
Henry Thomas
