Question about Univex 746 Watts SRM30+ Stand Mixer
Spinning part throws out metal shavings into dough that im mixing
I have on of these univex standing mixers and it used to work fine and recently as I was mixing dough i noticed that little metal shavings started falling out from the round spinning part that makes the attachments turn.
What could be done to keep this from happening?
bigg t
  • 640 Answers
SOURCE: Univex mixers
Im not bias on my opinion,but from the repairs i do on mixers hobart mixers are far superior than other manufactures.Hobart is over 100 yr old company that started with mixers and their service dept. is good.unlike any mixer out on the market they mirror off of hobart.
Posted on Nov 30, 2007
SOURCE: viking stand mixer dough hook will not come off
Had the same problem with dough hook not coming off. Sent to a Viking dealer in Rockford and was quoted $600. to replace gear box. Took it back without repairs and call Viking listed in manual and sent it to them on a Monday and by Friday had it back fixed and no charge.DM
Posted on Mar 09, 2008
r carbo
  • 21 Answers
SOURCE: Hobart L800 mixer
that is not true i work on these mixers in nyc and all the pizza places in manhatten use the L800 i dont know what it stand ford but will find out and post it on friday this is the best machine money can buy!!!!!!!!
Posted on Nov 19, 2008
  • 145 Answers
SOURCE: is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Posted on Jul 07, 2009
  • 145 Answers
SOURCE: KitchenAid 600, Stand Mixer -
If the beater is grinding when it meets resistance, it generally indicates that an internal gear has broken or been stripped.
With the Professional 600 stand mixer, up to 14 cups of white flour or only 8 cups of any flour are recommended at one time. Speed 2 is the only speed that should be used for bread dough and it should never be kneaded for longer than 7 minutes. Failure to do any of these things make cause problems for the mixer motor.
If you are interested in self-repair, I recommend mendingshed.com. They have internal parts available to order and also have a .pdf file for the Kitchenaid Mixer Service Manual.
If you are interested in a repair facility, please visit the following link:
http://caservice.kitchenaid.com/
This is a listing of certified repair locations.
Also, if the mixer is less than a year old, Kitchenaid may replace it under their 1 Year Manufacturer's Warranty. I would recommend calling their customer service. Their toll-free telephone number is:
1.800.541.6390
Posted on Jul 16, 2009
Broken gear
Refer this problem directly to Hamilton Beach as the primary source of the parts.
Dec 12, 2013 | Hamilton Beach Eclectrics All-Metal Stand...
Kitchen aid mixer makes a sqealing sound. Can
yes it can. just above the rotating head there is 5 screws that can com lose and start rubbing the head as i turns. there is a pin in the the bottom of the spinning head and the only way to get to the screws is to push that pin out and slide it off. there is a few ways to fix the screws from coming out. one is to buy lock washers. these won't allow it to back spin the screws. but you will have to use a file to shave the part of the washers that sticks out. this is the sure way that it won't come out. or you can put lock tite glue to lock them in, but if you need to ever get the screws out again you will break them. before you put the rotating head back on you will need to clean the old grease out because it has metal shavings in it. them replace with a gear grease. just small dabs should do. to much will throw it into the mixing bowl. just put it back together and your good to go.
Feb 16, 2010 | KitchenAid K45SS Classic Stand Mixer
Can you use a spiral dough hook when the mkixer runs in reverse?
You can but the dough would ride down towards the bowl instead of up and your mix would not turn out properly.What kind of mixer do you have?i'm a hobart tech and repair these mixers often.Let me know.
Nov 04, 2009 | Hobart H600 Stand Mixer
Professional 600 - makes loud noise when mixing,often stops as it blends 8 cups of bread flour and "needs a break", flat beater seems to get caught on bottom of bowl - this mixer is 1 yr. old!!
Several things:
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
Jun 24, 2009 | KitchenAid Food Mixers
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
Loud and throws flour all over
Do you find the motor running too fast at the lowest setting? Then you need to bring it to someone to adjust the low speed setting. If you are preparing double batches you are over loading the mixer and/or using too fast a speed setting to mix. Don't try to double recipes just because the bowl can handle the volume, the motor cannot and will not last very long if stressed mixing dough frequently.
Nov 13, 2008 | Betty Crocker 340 Watts BCF1250 Stand...
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
Univex mixers
Nov 29, 2007 | Univex 250 Watts SRM12 Stand Mixer
Univex 746 Watts SRM30+ Stand Mixer Logo
49 people viewed this question
Top Univex Food Mixers Experts
Oscar Netto
Oscar Netto
Are you an Univex Food Mixer Expert? Answer questions, earn points and help others
