My brand new radiator heater is not heating up quicky. Is it a defected one?
    Genius:
  • 2,920 Answers
They aare slow to heat up and disperse heat according to the coldness. its not a faulty unit
Posted on Dec 06, 2008
Quickie homepro steam mop not working, it's plugged, it has water, it's also brand new, it's my first time trying to use it
If you have done EVERYTHING according to the instructions received, waste no more time and return for another working unit if still under warranty.
If expired then your are in trouble. Have some one else set it up and see if they can get to work. If they cannot then you have a DOA unit that you should have checked the moment you purchased it. An expensive lesson.
Sep 07, 2015 | Quickie HomePro Steam Mop
My mazda protege is having a heating problem. The temp guage will go up to the normal place as the engine warms up but then when I drive down the road the temp guage goes down to below cold and then my car...
I believe the mazda protege has a separate thermoswitch to activate the radiator's fan. Perhaps the fan keeps blowing until the temperature is too low. Try replacing the fan thermoswitch. Just take care to put in tis place a thermoswitch of the same temperature range.
Nov 11, 2013 | Cars & Trucks
No heat for 2000 lincoln ls
You have a defective air temperature control blend door actuator or blend door is jammed due to heat warping. To replace the blend door requires the entire dash be removed form the car.
Mar 11, 2012 | Lincoln LS Cars & Trucks
No heat in 2001 dodge stratus rt. Wondering if there is a blend door or a control valve I should be looking for in my make/model? The heater core is not leaking (pretty sure) but may be clogged, or one...
if your radiator is leaking then i would say you are low on coolant. the heater wont work when the coolant is low. i would see what happens when you get the new radiator in tomarrow.
Dec 14, 2010 | Dodge Stratus Cars & Trucks
Is there any other reason why on a 97 geo prism that a brand new thermostat won't open other than it is defective? I put Bar's head gasket repair in it and now I have no heat. Old thermostat was stuck in...
Yes I've seen bad thermostats right out of the box. When installing it make sure that the point-points towards the radiator (flow). The best way to test the thermostat is to drop it into a pot of very hot water to see if it opens. I hope I've helped. If so please rate my assistance and leave a comment to help others with a similar situation.
Dec 09, 2010 | 1993 Geo Prizm
No heat on my 98 caddy deville delegance?
do the heater core coolant supply hoses both get hot at the firewall in the engine compartment? if yes then you have a defective temperature control blend door actuater motor.
Oct 17, 2009 | 1998 Cadillac DeVille
'95 sierra 2500. not heating up. replaced thermostat .
check and see if the heater valve is opening. it should be on one of the heater hoses. If it is open make sure that all the air is out of the engine. check and see if both sides of the radiator are the same temp. They should both be the same. If it was working before you changed the stat, then it could be a bad stat
Feb 28, 2009 | 1995 GMC Sierra C1500
Over heating
The brand new water pumps are junk. I put a reman water pump on and it works great.
Jan 10, 2009 | 1995 Chevrolet Monte Carlo
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
