Washing Machines Logo
Posted on Jun 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg washer makes a scubbing noise - LG Washing Machines
ernesto cuadra
Level 3:
Top Expert:
  • LG Master 12,223 Answers
  • Posted on Jun 29, 2012
ernesto cuadra
LG Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4076289
Points
34431
1) normally the noises coming in spin cycles. You need to re-balance the clothes load.
2) Re-balance the clothes and repeat the step if necessary and try again.
3) of course try to Level the machine, with the instruc.manual procedure.
God bless you
1 Related Answer
Anonymous
  • 95 Answers
  • Posted on Nov 18, 2009
SOURCE: LG WM0642H front load washer making a loud vibration-type noise
mc not level
My LG washer makes a horrendous noise when it in use. what could cause this?
Open door and see if you can move inner tub without the outer rub moving. If you can the 'spyder' which hold inner drum to axel hub is broken. Post results in comment section
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
My LG Wahining machine is making a rattling noise and will not spin or drain.
For the washer to spin, it must first drain the water out of the tub. Since you are hearing a rattling noise, and your washer will not drain, most likely the problem is the drain motor itself. The impeller wears out on the shaft, and start to wobble, and make a vibrating/rattling noise.
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
3answers
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
2answers
My lg washer shake s alot when it is spining and makes a loud noise please can you help
The washer needs to sit on a solid foundation for this to work. When the washer is spinning a load of clothes, push the corner of the washer till the noise or vibration quiets down. When it does quiet down, adjust the leg below to reduce the noise.
Good luck
When our new LG washer starts its cycle, the water seems to do quick bursts into the washer making the pipes make a bad noise. Any advice?
The quick burst of water is normal for the LG washing machines, its the way the water valves work. The noise you hear, sounds like the water lines jerking, and hitting against the wall, or the cabinet itself. You may need to get some tape, and tape the lines to the unit itself.
2helpful
Lg wm1832cw front load washer
One of 2 things may be causing the loud noise.  Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive).  Either way, you will need a qualified LG technician to diagnose and repair the problem.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
