Question about Dell A215 Computer Speakers
Speakers produce effect noise but no music...
I just had to re connect my computer due to furniture moving. i kept checking the speaker cables ove and over and found no problem. not a sausage! if some one could help me figure this out i would really appriciate it!
Check to make sure you have not lowered volume or muted any sounds--- go to speaker icon in tray, double click and check to make sure all sounds are on! Hope this helps.
Posted on Apr 22, 2007
Hello, I just bought a BEHRINGER MS40 from an authorized dealer "SENIA" from Romania, I'm from Romania by the way, the woofer speaker from the right side is making noises when the frequency is...
Have you connected the Left speaker to the right speaker using the supplied cable? If not, connect the cable to the socket on the back of the right speaker labelled "to left speaker" and on the left speaker, to the socket labelled "from right speaker"
If this still doesn't solve the problem, try swapping the input cables (put the white plug in the red socket and vice versa) to see if this makes the left speaker produce sound, if it does, check the connection at the source to check the plug(s) are in all the way. If there is still no sound in the left speaker, unplug everything and do the following:
connect the left and right speakers with the supplied phono lead (Probably black) between sockets labelled "to left speaker" and "from right speaker"
then connect the source to any of the inputs on the back of the right speaker (ensure if using the red and white phono inputs that both are connected)
finally plug in power source.
Hope this helps
May 04, 2011 | Behringer Ms40 Digital Monitor 40watts
I don't know to connect Logitech speaker to my computer.
Plug the green stereo cable to your PC (Green port on PC too)
Connect the black connector (Round shape) to the back of the sub-woofer (big box)
Play music on your PC, should work like a charm...
Hopefully you have already tested the PC to work fine and produce sound. Else you will need to t/s the PC to fix it...
if the PC is probably broken / port is broken - you can connect your iPOD or other music player's green port too - will work just fine!
logitech_r-20_001.jpg?1286435471
Apr 01, 2011 | Logitech R-20 Computer Speakers
Woofer 4650 carcit digram
Establishing computer speakers includes networking to the devices from where media from be derived either as computers stereos of media players. First, the speakers require connection established between each component sound producing device that has an impression in generation capacity. Second, the speaker device have a box usually the woofer as central area with power cuicuit features. Connectable cables are power cuicuit related expected to extend from the woofer to the power outlet. Also, the woofer board would require as last connectivity, the cable attacchment to the devices that produce sound either as stereo music medis players, digital media displayers among mentionable media devices.
Feb 14, 2011 | Creative Labs MegaWorks THX 550 Computer...
My sound is all distorted
  • Make sure your speakers are correctly connected to your computer.
    On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a USB cable, it will plug into any USB port on your computer.
  • If the music in your library skips or the audio breaks up when you play it inWindows Media Player, there might be a problem with the audio driver installed on your computer. Typically, this type of problem only occurs toward the end of songs (in the last 20 seconds or so).
    In some cases, you can work around the problem by disabling optional speaker effects that are collectively known as enhancements. If disabling speaker effects solves the problem, you might need to update your audio driver.
Jan 21, 2011 | Packard Bell (030069) Sound Card
Two speakers hum noise
Very doubtful that hum issue is ground potential difference from multiple power outlets as power cord is not grounding type (it is transformer isolated). I do agree that it is good practice to connect all audio equipment to common power strip though, especially with pro sound. Check the audio cords connecting your speakers to the coumputer sound card: 1) Make sure they are connected to the correct jacks and plugged in all the way, 2) wipe the connectors off with a clean paper towel wetted with a smidge of WD-40, 3) replace cords if all else fails. I have also seen solder joints fail on the power supply capacitors (due to vibration) causing hum -- but leave this repair to an electronics technician due to dangerous voltages.
Sep 25, 2010 | Altec Lansing AVS 500 Computer Speakers
I have a Toshiba & my speakers make a really horrible sound whenever the laptop is moved. Is this a defect? I think I should take the computer back. It does it when I am streaming music !
it is due to electromagnetic waves produced by the laptop
it is not a defect
same effect when we get a call on a mobile which is placed near speaker
Aug 29, 2010 | Toshiba (P000377700) Computer Speakers
I am getting a fuzzy sound from the vocalist 4 on my guitar, almost like if you strum the strings and forgot you "stored" your pick between the strings.Can you help? Thanks
This MIGHT be typical digitizing noise that can occur with a digital effects processor when the signal level is too LOW. The signal gets down in the noise because it only uses a few bits of data which means LOW resolution in the effects processing.
Make sure your guitar is producing the level required by the vocalist.
Weak battery in amped guitar is common...REMEMBER always send the signal between devices at least at half the max volume to keep a decent signal-to-noise ratio.
ALWAYS use instrument grade cables between the devices and speaker cables for speakers... NEVER use the incorrect ones for either of these functions. They should be labelled.
Dec 26, 2009 | Digi-Tech Digitech Vocalist Live 4...
Please Help!
I had the same problem: speakers worked, but clicked whenever they were on. They are actually Compaq speakers connected to a Dell computer. I solved the problem by moving the speakers about 12 inches farther away from my wireless router. Very easy!
Sep 09, 2008 | Dell A215 Computer Speakers
Noise when changing the volume and connecting speaker to anything.
firstly check the cable, some times it may in loose contact
otherwise any radiation equipment is located near by the amplifier,
sol. replace the location of the amp. and check cable loose contact
other wise
it is due to its amplifier IC problem, it is weak due to over load signal, or temperature of IC make leakage
sol.replace IC
Oct 24, 2007 | Logitech Z-5300 Computer Speakers
PROBLEM WITH SONY WOOFER
This must be cable connection problem. There may be loose connection or cable is not working properly so change the cable and enjoy. Thanks
Aug 10, 2007 | Sony DAV-DX255 System
Dell A215 Computer Speakers Logo
Top Dell Audio Players & Recorders Experts
Steve Allison
Steve Allison
ptpumpman
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
