Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
The tv will not turn on makes a noise and the green light will go to red and flash 7 times, what could be the problem?
  • Anonymous Dec 22, 2008
    there's also a cracking sound
It is the projection lamp or bulb. I had the same problems. You need to replace the lamp which is located in the front under the cover. The plastic cover extends the length or width of the TV. The cover can be kind of tricky to take off, but it is just held in by pop-in type rivets that snap in like a male into a female hole along with removing the 2 large screws on the back side on each left and right side. After you remove the screws the front pops off and it may feel like you are going to break the plastic front cover, but it does pop off and pull straight out. The lamp will be visible right in the front and is held in by two screws and after removing the screws the entire light assembly slides right out which is plugged into a socket. You can buy just the bulb or for a few dollars more the entire plastic box assembly with the bulb already in it. Hope this helps.
Posted on Jan 10, 2009
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Tv wont turn on
I have no clue who makes your TV or the model so I can't really help you. Count how many times it flashes and start googling for the answer. Include all the info you can next time.
Dec 29, 2012 | Televison & Video
Green light blinks 7 times on flat screen before turning red. there is a picture for 5 seconds
Good morning
Take the remote and find set up and picture. Try to adjust the brightness and see if you do not get rid of the green light.
all the best
kolbrun
Jul 08, 2012 | Televison & Video
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
My tv will not come on. It flahses red 7 times.
u have 2 bad capacitor on power supply , they are very small ,
Apr 15, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Red light
sounds like its time to look into getting a replacement bulb.
Jul 18, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
249 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
