Question about Mitsubishi WS-65809 65" Rear Projection Television
Tv screen is squeezed only straightens out if i bump the top of tv
  • ctryboi28 Dec 06, 2008
    any idea what that would cost to have done
  • 505 Answers
This is likely your convergence IC solder connections. Does it look bowed and rainbow colored? The red, green, and blue will be mis-aligned causing a shadow effect. If you can bump it then the ICs (chips) are still ok, it just needs resoldering.
Posted on Dec 06, 2008
  • thielectronick
    thielectronick Dec 06, 2008
    my company charges $300-400 for the full repair (replacing ICs, full realignment plus cleaning)
    if you can find a company that will resolder for you, it could cost $100-200 maybe. if you are a handy person with soldering skills, you could repair yourself. i can instruct if needed, but convergence IC soldering requires decent soldering skills.
Samsung Ln-T4671F screen is getting darker. The whole screen is darker, not only the right or the left. Also a red vertical line appeared about a year ago, haven't noticed since- don't know of its...
MOST LIKELY YOU HAVE A DEFECTIVE LCD PANEL. Try lightly squeezing the top of the TV. Start from one corner and work your way slowly to the other side. If squeezing the top of the frame clears up the screen problem, you have a defective LCD panel tab. The only true repair is the replace the screen. This cost for a replacement panel could cost more than a new TV set.
Sep 03, 2012 | Televison & Video
The screen of my 6930 Acer Lap top cracked and it was not dropped or abused, any suggestions as to why this happened, is this a common problem of the Acer laptop?
A lot of laptops can have their screen broken from impact to the lid while the screen is closed. When you have it in a case or in a backpack and you lean/sit/drop the bag it can give pressure when you don't think it will. It's a common problem for any laptop in those situations and not necessarily Acer Specific.
Mar 04, 2011 | Acer Aspire 5500 5570-2609 Laptop
Philips 47-Inch 1080p LCD HDTV - model 47PFL3603D - worked great until we tried to move it - it was bumped very lightly, and the picture now only shows 1/2 the screen
There are two ribbon cables at the top centre of the display, if one is loose, you will only have half a screen. When taking a small bump the cable has become loose. Check the ribbon cables and connections.
Jan 11, 2011 | Philips 47PFL3603D LCD TV
Picture on TV ''squeezed'' to center of screen horizontally
Check the horizontal trafo output voltage,the capacitors and the power supply voltage (135-155V dif.the tube diameter).
Aug 14, 2009 | Panasonic Televison & Video
Need instructions on replacing filter head on a haywad de filter ec75a
Remove the nuts and bolts around the head of the filter. The top then seperates from the bottom. if the top of the tank is broke you need to remove the black cover and continue disassembly.
Remove the grip from the handle. Usually a squeeze clip to slide grip off. Slide black cover over handle.
Remove bolt holding handle on to bump shaft, might be addtional drift pin that needs to be removed. Tap out with a drift punch.
Once these are removed the bump shaft will be attached to the top and bottom plates with the main gasket still attached. The filter Head is now free to be replaced.
Apr 24, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
3 inches missing on both sides
Sounds like it is a widescreen TV stuck in standard view mode. Should have a menu option called widescreen or movie format.
Do you see the whole picture squeezed down or is it actually cutting off the sides of it?
Jan 08, 2008 | Proscan PS32125 32" TV
40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Jan 06, 2008 | Samsung LN-S4051D 40 in. LCD Television
Broken Screen
realy the only thing you can do in this instance is nurse it along
as you are doing, until you can get ti repaired.
the damage is done now and pressing and squeezing it is your only
solution. Im afraid there is no quick fix for this.
if you can use a desk top monitor the will be a great use
it will just plug in the back of the lap top not ideal but it will keep you running for now until you can have it fixed.
hope this helps you out
please rate me fair
Nov 12, 2007 | Computers & Internet
Mitsubishi WS-65809 65" Rear Projection Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
