Question about Futaba Toys
Battery connectors broke
Help please i have a futaba r/c for one of best trucks and one of my battery that connects + and - its like a clip slash spring broken ive looked it up at radio shack nothing ebay even went to a hobby store and all they wanted to do is sell me a new one it holds 8 aa batterys next to eachother.it had battery acid so when i put a battery it broke.any anwser please let me know where can i find the the parts thanks
  • 1,498 Answers
Hey there NewYork691,
I'm from Long Island. The name is Mike and I may be able to give you a more economical solution.
From your description, it sounds like one of the contact that connect the (+) of one battery to the (-) of the next battery broke. If that's what happened, no worries, you'll be fixed in no time.
Find yourself a penlight, remote or any other device that uses AA batteries that you aren't going to miss. Open up the battery compartment and remove one of the spring contacts.
You may have to hunt around to find something similar, but all it has to do is fit in and make contact. The compartment cover will hold the batteries in.
You should be back in business.
Mike
Posted on Dec 06, 2008
Futaba PULSCALE Manuals
I'm using Futaba Pulscale 2000.
I can't change the unit from Inch to MM. and I got problem to change " R" ( Radius ) to "D" ( Diameter ) into each axis of " X " or " Y " individually.
Please help to solve this problem. Thanks so much.
Sep 10, 2013 | Toys
Futaba t6x instrutions
I have found a solution! Go to this website. It is the company of your device and they have a manual for you!
www.futaba-rc.com/downloads/manuals.html
Hope I helped!
Nov 22, 2011 | Futaba Toys
T2er no information on how to charge batteries
YOU SHOULD HAVE A CHARGING UNIT WITH 2 LEADS 1 IS A JACKPIN THAT PLUGS INTO THE TRANSMITTER THE OTHER LEAD HAS A CONNECTOR SIMMILAR TO THE BATT TO RECEIVER IN THE HELI IF YOU HAVE A REMOTE CHARGING SOCKET IN THE HELI JUST PLUG IT IN. IF NOT DISSCONNECT THE BATT FROM THE RECIEVER AND CONNECT DIRECT TO THE BATTERY
Aug 18, 2011 | Futaba 6CH Digital Transmitter and...
Regarding the BLS452: 1 What is the maximum (electrically driven) rotation? 2 What are the pulse widths for the maximum rotation? 3 What is the current consumption on 6V? 4 Is it digital, & if...
Some of the information you're requesting is at the following link.
http://www.helipross.com/futaba-bls452-brushless-ep-car-high-torque-servo.html
The current consumption will be dependant on the loading of the servo.
Digital Servos give and quicker resoponse to your input and provide a higher torque in a shorter period of time. Full explanation st the following link.
http://www.futaba-rc.com/servos/digitalservos.pdf
Jun 23, 2011 | Futaba Bls452 Brushless Ep Car Hi-torque...
I am trying to locate a Manuall for Futaba 7c radio transmitter thank you Andrew Wilson .
Glad to HELP YOU!
You have HERE a list of ALL MANUALS (scroll down until you will see your 7c product) and just HERE the manuals for a SIMPLE 7C RADIO TRANSMITTER (as you have indicated in your post).
My best wishes!
Mar 17, 2011 | Futaba Toys
I just purchased a Deltran Battery Tender Junior to charge the weak battery on my motorcycle. I was told to hook it up to the battery of my 2008 Yamaha Royal Star Venture. Butl in reading the directions,...
Jerry ,
An alligator clip is not required . just connect your terminals the right way . The red ( positive ) to the positive + on the battery terminal and the negative to the - of the battery . Please ensure to have the ignition turned off while you are charging the battery of you may " cook " some relay or CDI unit which is the main brain of the ignition system . Make sure to have good contact between the charger and the battery . The best way to recharge a battery is to disconnect the terminals from the bike to the battery and connect the charger alone to the battery to avoid any damage . Best of luck with that
Jan 05, 2011 | 2008 Yamaha Royal Star Venture
I broke one of the connectors while changing a fuel filter. The two hoses that run to the rear of the van,I took the front one off,But when I tried to remove the back one the plastic connector broke on me....
Relieve system pressure. Disconnect battery negative cable. Drain fuel down as much as you can, support tank and lower/loosen straps to get access to pump & see what your missing or what broke. May be just retainer clip.
Jul 11, 2009 | 2000 Dodge Caravan
1994 Nissan Altima alternater connector
Sounds Like you need all new plugs and plug wires. Change your cap and rotor while you are at it!
Apr 24, 2009 | 1994 Nissan Altima
Battery cover
I'd suggest cardboard and duct tape. The same happened to me. You can also try gluing small pieces of Velcro to fasten closed that way. To the best of my knowledge, that clip can't be replaced.
Nov 05, 2017 | Olympus Camedia C-5050 Zoom Digital Camera
No start. Has new battery, fuel filter, fuel pump, and coil. Started in A.M., drove in rain to work...would not start in the evening. (?)
check all your wire connecters around your fuel injection assembly, had gone to the car wash once and cleaned engine, clips on wire connectors was broke and weak lock allowed water in and complete loss of relay. blew moisture out and away we went.
Jul 30, 2008 | 1987 Chrysler New Yorker
Toys Logo
182 people viewed this question
Top Futaba Toys Experts
Michael Vincent Cruz
Van Allen II
Van Allen II
matt
matt
Are you a Futaba Toy Expert? Answer questions, earn points and help others
