Question about Dishwashers
It has a hot smell after after it runs for a while.
If i
    Genius:
  • 2,920 Answers
Your motor is going out on the dishwasher
Posted on Dec 06, 2008
I have a 2002 Mitsubishi Diamante the coolant fan will not come on. The gage says it isn't hot but it smells hot. What could be the problem ?
check fuses and relays -engines smells hot [all engines put out heat and smell hot ]could be nothing the engine could be running correctly or test the temperature sensor ,fan motors and fan circuit --if smells hot because of leak look for leak have coolant system pressure tested
Oct 15, 2016 | Mitsubishi Cars & Trucks
DG 50000. Why is there a hot burning smell when it is running?
The motor, the pump, or the heating element could be getting ready to fail.
Oct 03, 2015 | Indesit Dishwashers
What is makin my 2001(3.2 liter)dodge intrepid run hot and smell like gas??
If vehicle running hot make sure coolant level is full. If ok, you will need to look at the thermostat operation and fan operation. The fuel smell may be due to a hot engine
Aug 01, 2015 | Cars & Trucks
What is causing my car to run hot with a smell? its 199
The smell is most likely the anti-freeze you smell. You may need a new overflow cap, which over time will not hold pressure like it should and can cause you engine to run hot and lose coolant. It could be the water pump leaking, a hose leaking. Can you see where you may be losing coolant at? How often does it run hot? Do you have to re-fill after it runs hot. If you not having to add coolant, then your thermostat may be bad or the water pump. But losing coolant could be the overflow cap or a hose, and let's not forget the radiator could have a small hole or split somewhere. It's a matter of finding out where or what are it is leaking in.
Sep 07, 2010 | 1998 Ford Crown Victoria
When it runs, it runs too hot even on low and burning smell
needs new thermostat DO NOT USE IT IS A FIRE WAITING TO HAPPEN
Sep 18, 2009 | Kenmore 62602 Electric Dryer
My honda accord wagon smells hot i stop running car, ther,s no leaks do i need a termostat?
You may have a bad thermostat or a weak water pump or a clogged radiator. Smell does not indicate if its hot. The gauge or coolant light might suggest its getting hot. You may have a fuel control issue that is overheating the catalytic converter which would smell or an oil leak that is dripping onto a hot surface causing a smell. You may have a real small coolant leak that you cant see that could cause this also.
Sep 09, 2009 | 1995 Honda Accord
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
Runs hot and smells
YOUR BELT IS PROBABLY BURNING UP
NEED TO REMOVE OUSTIDE HOUSING AND REPLACE
BEFORE TACKLING, HAVE SOMEONE TILT MACHINE BACK AND CHECK THAT NOTHING IS INTERFERING WITH TENSIONER PULLY
May 26, 2009 | Dryers
Not shifting into gears, car smells hot
your tranmission is sticking causing the engine to work harder thus making it run hot.
Mar 27, 2009 | 2004 Cadillac SRX
The coolant smells bad
If your engine is running hot, yes that could cause light to come on, as well as a strange smell. Have it checked a.s.a.p. otherwise it could cost you a lot of money, if it hasn't already. Don't drive it if it's running too hot. Make sure you add coolant as needed before you try anything.
Feb 26, 2009 | 2000 Pontiac Grand Am GT
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
