Question about Dryers
Have amana dryer # LGA30AW and it is not getting hot. I opened the front lower access door and the igniter seems to be working just fine. Does this mean it is eather the coils or the gas regulator or could it be something else? Any input will be greatly appreciated. thanks
  • SAM0071 Feb 27, 2009
    Was the problem to coils? My dryer lights and fires but than fire stops after a few minutes. It attempts to light again but doesn't ignite
  • Anonymous Apr 26, 2009
    The gas comes on and lights just fine, then goes off after 10 seconds, then reignites every 60 to 90 seconds, again for only 10 seconds at a time
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
  • 14 Answers
SOURCE: no heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Posted on Jul 25, 2008
  • 8220 Answers
SOURCE: Maytag Gas Dryer SDG515DAWW - heating stopped
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
Posted on Jan 04, 2009
  • 2651 Answers
SOURCE: I have a Amana Gas Dryer. Model No: LGA30AW.
sounds as if the coils atop the gas valve have gone bad, no longer opening the gas after initial lighting,, order and replace them (part number 279834.. yo can aceesthem by removing the front lower panel and using a stubby phillips screwdriver, easy repair for about $25
Posted on Feb 13, 2009
  • 2651 Answers
SOURCE: how to remove lower front panel/amana gas dryer model ndg2330aww
look under the fornt panel 2 5/16 screws holding it on
Open front panel on maytag Sde3606ayw?
there are 2 screws near the floor below the door that will let you access the lower front area,then you can remove the door assy and finally the top cover if necessary
Apr 19, 2010 | Dryers
Lga30aw burner won't stay ignited
The gas valve coils are weak and must be replaced.
Jan 17, 2010 | Amana Dryers
My dryer doesn't produce heat. the coil ignites
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. In your machine, it appears Amana doesn't sell the coils as a separate item and the whole valve needs to be replaced. The part number is Y504091.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
At front, remove 2 screws near floor at the bottom of the lower front panel. Pull bottom of panel toward you and down. The gas valve should now be accessible on the left. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble.
Sep 17, 2009 | Amana ALG331RAW Gas Dryer
Amana LGA30AW Gas Dryer won't produce heat
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Sep 11, 2009 | Dryers
Where can I get a lint catcher for an Amana Gas Dryer Model No: LGA30AW.
You can buy a Lint Catcher/filter for your Gas Dryer from this link---
Amana Gas Dryer LGA30AW Lint Filter
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Apr 28, 2009 | Amana Dryers
Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Mar 27, 2009 | Amana DLG330RAW Gas Dryer
Feb 12, 2009 | Amana ALG331RAW Gas Dryer
Amana gas dryer fine on regular settiing, poor on delicate
It would be unusual but this could be a bad timer in the control panel. The only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru ---
Jan 26, 2009 | Amana ALG331RAW Gas Dryer
Dryers Logo
255 people viewed this question
Top Dryers Experts
