Unable to read drive - Computers & Internet
  • Alan Matzke
    Alan Matzke May 11, 2010
    you need to give me more info than that to know where to start
    make , model. biigg53566
  • 781 Answers
If it is a hard drive...the drive could be/have:
data or power cable may not be seated properly or failing
the jumper may not be set correctly
not initialized yet
not formatted yet
or could be failing itself
if it is a cd/dvd drive.. the drive could be/have
the disk may not be in a suppoted format (ex. using a dvd in cd rom drive)
the disk may be scratched or damaged
the lens may be dirty or not properly aligned
firmware maybe outdated.
if drive is a removable drive/flash drive the drive may be:
not powered
data cable not connected/failing
the usb/firewire port may be failing.
not initialized
not formatted
failing in itself.
Posted on Dec 06, 2008
I have a dell 755 that the CD drive won't play certain CD's. It is not the CD because it plays on other machines. Some CD's will play just fine. Get's the error message Unable to Access Drive D tr
it depends on the files on the cd ...they might require a certain software to be installed in order to be read..for example the player may not be able to read mp4 without a codec installed ..or vcd (video cd ) to need a dvd player installed or a player that supports video cd and dvd-es..Same way for other file types...or ...certain speeds being imposed on writing ..and your cd drive to be unable to read them on those speeds..
Nov 09, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
Unable to read any discs
Try keeping off your system for 10-15 minutes and try again. If problem exists go to the shop from where you bought your PS3 and ask them for replacement of your drive or your drive lens. I think drive sounds better.
May 16, 2010 | Sony Playstation 3 (PS3) Console
Unable to read files on flash drive
Files must be corrupted or the disk is write protected
Nov 06, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Unable to read discs
Take a can of air and gently blow some into the drive to make sure that the laser has no specs of dirt or dust on it.
If after you do this you still can't get the Wii to read any discs, then the drive is bad and would need to be replaced. It is also possible to replace just the laser but that would require opening up the drive to get to the laser so replacing the drive would be the easier option.
Aug 21, 2009 | Nintendo Wii Console
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Unable to burn dvd using LG DVD ROM
your DVD Rom drive cannot burn DVDs because it is not a DVD burner, DVD Rom drives are different from DVD writers, if you want to burn DVD you must buy a DVD burner/writer.
Jan 10, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
