Question about NEC MultiSync VT45 Multimedia Projector
Flashing red status light on NEC VT45 projector
There is a flashing red light on our school's VT45 projector. The lamp has been replaced but the flashing red light remains. Any suggestions to try?
  • 3 more comments
  • Anonymous Feb 12, 2008
    I have the same problem on the NEC VT 440... the machine actually dropped and the light came on..... we are desperate to find out... I have opened the machine up and made sure all of the connections are tight but still have the problem
  • zordlor Jun 23, 2008
    i have exactly the same problem with my 440. i dropped it but the bulb etc. seems fine, yet it still flashes red and wont turn on. i don't have a remote to try the pressing and holding "help" button option. is there anything else i can try?
    there is a tiny button which is activated by the filter cover, letting the (NEC VT440) projector know the cover is in place. my button is broken, so the projector thinks there is no filter cover and won't switch on. i got it to work for a while by blue-tacking a paper clip inside to hold the button in place, but it stopped working and is very fiddly... is there any way of overriding this safeguard? it's especially annoying because i know the rest of the projector works fine!
  • cashforex Jun 28, 2008
    my problem is similar but the red light is solid. no remote. please advise
  • chris7sam Jan 02, 2009
    Does anyone know how I fix my VT45 if the orabge lite is constant with an 8 second red flash. I think thats "fan error". The manual doesnt say how to fix these errors. The fan appears to be working, and the fan door is snug. This projectore has worked flawlessly for 6 years (mounted to ceiling). I presses the help button on the remote as advised during start up and shut off with no response. Any othewr ideas. When I start the projector I hear a series of tiny clicking noises. It almost sound like the igniter on a gas grill, only much quieter. It does it a few sets of times, then the projector goes into shutdown mode.
    Problem Solver:
  • 4 Answers
Make sure the doors are shut all the way! there is a little button there.
Posted on Sep 15, 2009
Press and hold down the help button on the remote pointing it towards the projector for at least 10 secs.
Posted on Mar 03, 2008
NO IMAGE
Posted on Nov 13, 2008
NEC VT45, constant orange light with no picture anyone have some info?
Posted on Oct 05, 2008
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
My NEC vt 595 was working fine last night and today i went to turn it on the status and power light started flashing red and orange and there is no picture
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
Which is your condition?
Mar 18, 2011 | NEC VT595 LCD Projector
We use NEC MT1065 and just replace its lamp but it still won't switched on (lamp indicator led is red). How can I reset it ?
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, if your old lamp has only had the reflector replaced then it will make no differance because the chip tells the projector weather or not to power up depending on the hours its counted, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention, just as an added note, a solid red lamp indicator light means that the lamp has expired, if its flashing red this means its nearing the end of its life, if the status indicator light is flashing then there could be another issue, by counting the flashes you can reffer to the manual in the troubleshooting section to diagnose the fault, I know this is very late, but anyone else reading this may find it helpfull.
Nov 29, 2010 | NEC MultiSync MT1065 Multimedia Projector
Turn on the projector the power light flashes green with status as green then it goes to a flashing orange light
there should be a status for the lamp light; check to see if this one turns red. If it does count the consecutive blinks if it is 6 then replace the lamp
Apr 15, 2010 | NEC VT800 LCD Projector
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
Hi I am having trouble with an LT180 DLP I'm getting a series of error messages culminating in the power light steady orange and the status light flashing a series of 6 flashes red. Inside I found that...
both lights flashing green indicate the projector lost power while it was running (didn't get to go through shutdown procedure). if the status light blinks 6 times, the lamp is failing to strike (one time means the cover is open, 2 times is a temperature issue, and 4 times is the fan). if it comes on and shuts off a short time later (less than 15 seconds), the ballast is going bad and needs replacing. if it didn't come on at all, it'd be either the ballast or the colorwheel. if the lamp light was red, it would be the lamp that needs replacing. nec won't sell parts to anyone who is not an authorized nec service center, so you'd need to contact one to get the part (although they may not sell it to you). but good luck!
Aug 20, 2009 | NEC LT180 DLP Projector
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
Power light flashin orange, status light flashing red on WT610 NEC
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is: 2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path. 3 cycles - the power unit is not working correctly. 4 cycles - the fans are not working correctly 5 cycles - lamp fails to light. Wait a full minute and then turn on again.
Jan 25, 2009 | NEC WT610 DLP Projector
NEC MultiSync VT45 Multimedia Projector Logo
6,747 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
