Question about Porter Cable Cable RN175AR Reconditioned Roofing Coil Nailer
Porter cable roofing gun
The gun wont shoot it tryes to but acts like it is low on air when it shoots the rod that hits the nail wont go back up it stayes down . the gun doesnot leek air. if you push the rod up manuly it will shoot 1 nail and the rod stays down. can you give me some advice thanks charles
    President:
  • Porter Cable Master
  • 1,388 Answers
The problem that you describe could be caused by three things. First remove the cylinder and look for a black rubber band around the cylinder about med section. There is an indention with holes where it is supposed to be. The band should fit snuggly so that it does not slip off during use. Secondly, check that the piston oring/plastic ring holds the piston in the cylinder without just dropping under its own weight. Third, the upper bumper could have a crack or missing piece. Remove it and check. (vinyl part in headvalve) Parts are available at dewalt repair center or www.toolpartsdirect.com. enjoy
Posted on Dec 07, 2008
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
Miss fires and wont sink nails depth set deep and pressure over 120 psi
If no air is leaking from gun, miss-fire is usually caused by worn or too tight piston oring or lack of lubrication. Easy test. Disconnect airline, remove nails, point nose of gun up then down. Driver should stay in uppermost position. If driver moves up then down within gun replace piston oring and retest. Set pressure to about 100psi. Good luck with repair.
Oct 14, 2012 | Porter Cable Coil Roofing Nailer
Gun shoots one nail, driver does not return Porter Cable RN175
Internal damage - most cause by wearing parts
Bring to the repair shop
Oct 02, 2012 | Porter Cable Coil Roofing Nailer
My RN175 shoots you think it shot the nail, but when you move the gun to shoot the next nail the nail you just shot falls out the end of the gun. What could cause this?
The driver is coming down far enough to break the nail off the strip but not far enough to drive it in. This could be caused by any of the following:
- The driver is broken off and too short to drive the nail
- The driver is bent and doesn't travel all the way down
- The seal/o-ring on the piston is damaged and air is leaking past it
Any of the above will require you to remove the head and inspect the driver, piston and o-rings or have a service center check it out.
Mar 07, 2012 | Porter Cable RN175 Roofing Coil Nailer
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
When firing nailer first nail shoots good but next nails head will get stuck between the push rod chamber. push doesnt seem to return fully top when nail is cycled.
Try oiling the tool first. Remove the nails, squirt a decent amount of air tool oil in the stem where the air hose coupler connects, and fire the tool a dozen times or so. Then put in the nails and test. If it still hangs up then it will need the o-rings replaced.
Jun 11, 2011 | Porter Cable Coil Roofing Nailer
Why does my porter cable nail gun FN250B shoot
check the magazine bolts are tight and that the magazine is snug aginst the nose. also be sure you are using 16 gage brads and not 18 gage
Jan 23, 2010 | Porter Cable Air Tools & Compressors
My rooring nailer will shoot one nail and then the
Your gun is having a return problem, more than likely, the diphram on the top the of the gun leaking. You should be able to find a top end kit where you get your guns serviced/purchased
Aug 06, 2009 | Porter Cable Air Tools & Compressors
Porter cable fc350a frame nailer shoots just air
Could be a couple things, first are you using the right nails in the gun e.g. collation and degree. Second do the nails move freely in the magazine and how is the pusher spring on the nail does it have enough pressure. Then I would unplug from air remove all the nails andjust tap the nose on a piece of wood and does the driver drop? If so the piston Oring is worn and needs replaced, but if you do that I would recommend replacing all the rubber. Let me know and I would need the exact model number to come up with parts.
Jan 25, 2009 | Porter Cable Cable No. FC350A Clipped Head...
Porter Cable Cable RN175AR Reconditioned Roofing Coil Nailer Logo
429 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
