Question about Philips Magnavox 42MF521D/37 Television
TV makes "Pops" and "Crackles" sounds from the back while viewing
I have a phillips 36" Magnavox Smart Series Plus TV model number TP3684C101 (It is not a flat screen, LCD, or plasma...just the regular televsion set). Recently after I turned it on, it began to make a "pop and crackle" sound from inside the back panel of the TV and I could see a flickering light through the vent panel in the back of the tv. I was still able to see the picture perfectly but the TV itself sounded like it might explode (or cause some sort of electrical hazard). Could this be a replaceable fuse or some other repair that I can do myself? Any help that you are able to provide would be greatly appreciated. Thank you.
  • Regina21 Dec 06, 2008
    Thank you. Although I don't know how to solder, it is a tremendous help to know what my next step should be in possibly identifying the problem.
  • 58 Answers
Remove the cover and observe the source of the light. if its in the picture tube it can be fixed with a picture rejuvonator. if its a cracked solder joint a soldering iron and solder will fix it.
Posted on Dec 06, 2008
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips magnavox smart plus Model TP3284C101
if there is a DTV label on it , then it is digital .check the manual
digital would have the following : atsc ,hdtv ,digital tuner ,dtv
Jan 02, 2009 | Philips TP3284C 32" TV
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
Turn on and stay on
It seems that Your TV set may have a problem with its power supply circuit, the problem is intermitent bring it to the repair shop.
Nov 06, 2008 | Televison & Video
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Phillips/magnavox smart series
I have a Smart Series 32" Phillips-Magnovox TV I bought april '99. Around July 4 weekend 2008 it decided it just does not want to come on any more! Was working just fine before that...I can not find my manual. Any suggestions?
Thanks,
cely
ceorunner@aol.com
Mar 04, 2008 | Philips Magnavox 27MS343S 27" TV
Suddenly went off!
This is a power supply issue. Probably in the high voltage stages. Maybe a fuse, regulator IC, or Horiz. Output transistor or all of them. If you don't know anything about TV repair, you should take it to a shop that will provide an estimate to you.
Geno
Mar 04, 2008 | Televison & Video
Philips Magnavox 42MF521D/37 Television Logo
465 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
