Question about Lexmark Color JetPrinter Z42 InkJet
Using too much toner
I now have gone through 6 toner cartridges (black #70) in my Lexmark Z42 in the last four months. I put a cartridge in, do all the cleaning indicated and it prints fine for a while. The cartridge level indicates almost half full when the print begins to break up and eventually I can only print in color. Toner is expensive and this is getting way out of line. This problem began about a year ago. At first I thought the printer needed cleaning so that was done. I use the printer often but not that often. I buy only new cartridges. What's the deal? Thanks.
BondoFox
  • 40 Answers
SOURCE: Unisys UDS 25 Printer Problem - Identical to Lexmark T614
Your Unisys UDS 25 is actually a Lexmark Optra T612. Are you using OEM cartridges or recharges? If you're using recharges, that would explain the print quality issues. Was it light with the first cartridge as well as the second? The drum "being on its way out" is a moot point since the drum is replaced when you replace the toner, it's all one cartridge. If you have another printer of the same model, try the cartridge in it and see if the problem follows. If it does, it's the cartridge, take it back and get an OEM one. If the problem does not, then you may need a new image transfer roller. Let me know what happens!
Posted on May 29, 2007
leethedeuce
  • 4472 Answers
SOURCE: Lexmark z615 Printer cartridges not printing
First you might want to try and go to Start>Settings>Control Panel>
Double click Printer and Faxes
right click the printer. Then select the services tab. at the very least clean the cartridges.
Keep me posted,
Lee
Posted on Jun 18, 2008
easyq
  • 144 Answers
SOURCE: Lexmark E250dn laser printer
Reinstall the drivers and see if it works.
Otherwise unplug the printer from the power and leave it without power for 10 minutes. Than plug it back in and let me know if it helped.
Posted on Aug 08, 2008
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
Posted on Aug 19, 2008
sifon
  • 29 Answers
SOURCE: Lexmark x5495
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
929
Posted on Mar 03, 2009
Mx2300 write code f2-70 after replacing the black cartridge
F2-70 is indicating an improper toner cartridge K.
If you have just changed the black toner cartridge & the error appeared then the new toner is at fault.
Replace the toner cartridge with another cartridge, turn the machine off & back on & the machine should reset.
Hope this helps.
Dave.
Jan 09, 2017 | Sharp Mx-2300n Copier Color Mx2300n...
Removed toner strip (dam) prematurely
I don't think it should be any trouble putting it in a plastic bag and then putting it somewhere where it won't be disturbed.
Mar 03, 2014 | HP LaserJet 53X Black Toner Cartridge
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
$73.59
Nov 29, 2010 | Toshiba DP-85F Fax
Recently had a low toner message for black. Next time I went to use a fault appeared - incoreect cartridge. I replaced black toner with genuine Lexmark cartridge - message still appears. Have turned...
Nice job on trying different ways to resolve the problem - turning off/on the printer, removing power source, reseating the cartridges and even changing the cartridge with a genuine Lexmark cartridge. You pretty much did the necessary. Genuine Lexmark cartridges shouldn't cause you that much trouble. I strongly suggest you contact Lexmark technical support to further investigate the problem.
Sep 01, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Can't change Lexmark Z42 ink cartridge
You can unplug the printer from the power source. With the printer off, open the cover where the cartridge carrier is. Hold the solid white tape found in the middle inside the printer. Slowly drag the cartridge carrier to the center. Replace the cartridges. Close the cover. Plug printer back to the power source. Hope this helps.
May 03, 2010 | Lexmark Color JetPrinter Z42 InkJet
I have a Lexmark Impact S305 about 2 months old. Will no longer print black. Cartridge shows half full and tried cleaning, aligning, etc. This is my third black cartridge - I have changed it thinking...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 18, 2010 | Office Equipment & Supplies
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Not recognizing toner
Shake the toner cartridges.
Make sure the connections that are on the printer for the cartridges are clean.
Jun 17, 2008 | Dell 3100cn Laser Printer
My lexmark X1185 all in one printer will not print color.
did you make sure that you pulled all of the tape off the bottom of the cartridge. next recheck your settings. they will not return to normal themselfs
Jun 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer Color problems..
Seriously, buy a new printer. Companies sell toner, not printers! The printer is basically a "freebie" and is a marketing vehicle to sell toner. I tossed my C510 into the dumpster. It had four new toner cartridges. System diagnostics said that everything was at 95% or better. The printer had about 1600 prints on it. The first set of toner cartridges (full at purchase!) printed great. Then, I got dotted lines on clean prints. Or, I would get washed out, yellow tinted print and often, there was no black print. I called a printer repair shop and they laughed and told me to chuck the printer - they were suprised it lasted through the first set of cartridges. Lexmark literally "ignored me to death."
I will NEVER buy another Lexmark. The Brother and HP color lazers are probably the best bet. I have two HP B&W's that are paper pumps - an old 4V and a 6MP. The sad part is that I paid a bit more for the Lexmark than the competing HP. You live and then you learn!
Feb 25, 2008 | Lexmark C510 Laser Printer
Lexmark Color JetPrinter Z42 InkJet Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
