Question about Corona 23-DK Compact Heater
Corona heater does anyone know of a place I can my heater to and have them replace my wick ?
  • 39 Answers
Our ace hardware store in michigan replaces wicks your local hardware store may do the same, The guy there also helped me learn how to do it myself so I wouldnt have to pay to have it done.
Posted on Dec 14, 2008
I have a corona kerosene heater model # 22dk, will the wick from lowes fit my heater?
Actually, Ami there's know way to know for sure, unless you cross referenced the Part/Item number for the wick with what Corona requires.
Jan 25, 2011 | Heating & Cooling
Flame too low and putting off soot
Raize the wick up and trin off the burned section off Or replacethe wick.first take some of the kerosine place a clear glass ,should be as clear as water if not replace the fuel. Use only K-1.
Jan 22, 2011 | Corona 23-DK Compact Heater
Corona 23-dk heater burns fine when filled up but flames starts going very low a little pass the 1/2 line on fuel gauze. what causing that.
From your description, it sounds like the wick may need replacing or the tails of the wick are not hanging all the way down into the tank. And, therefore they are drying out. Thus, your flame gets low and eventually goes out. The only way to know is take the heater apart. If you're not comfortable doing that check with your local hardware stores, like True Value or Ace. many of these store do repairs on kerosene heaters and replace wicks. It can be a messy job, but someone has to do it.
Jan 21, 2011 | Corona 23-DK Compact Heater
I have a 23-dk corona kerosene heater. it was smoking so i replaced the wick. after replacing the wick it still smokes heavy. how do i fix the problem.
Check all airvents into conbustion chamber. Make shure they are all clear of blockage. The heater needs air to burn fule properly. Check wick adjustment it may have to much wick.
Sep 03, 2010 | Corona 23-DK Compact Heater
How to replace the wick in corona 23dk
I believe you will find the instructions on or in the package of the new one. I've seen many styles of replacement wicks at Walmart. Also the replacement instructions will be in your owners manual.
Dec 08, 2009 | Corona 23-DK Compact Heater
Button on wick adj. knob won't engage to remove or adjust
the wick could be dirty and or burnt not allowing for the know to be moved to the off position, I would suggest cleaning the wick or replacing before doing anything else.
Dec 07, 2009 | Corona 23-DK Compact Heater
Change wick corona dkc22
u need to start at top . remove cage from top. there should be a few screws on the side of the upper case (the round upper part of the heater) once that is removed u will see the shaft the wick is attached to,the heater control are mounted here too. there should be some screws or wing nuts remove them. now lift the shaft out the wick will come with it (carefull wick wiill be wet with kerosene) remove old wick. when replacing new wick make sure to allign the top of the colored band with the top of the wick holder(the piece with the pins that adjusts the wick up & down) lower shaft & wick back onto heater and reasemble heater .be sure all controls and shut off work smoothly and correctly.
Jan 10, 2009 | Corona 23-DK Compact Heater
Corona 23-DK wick replacement
yes the sleeve comes out and ther should be a couple little barbs holding the old wick in.fold the new wick to put it in making sure the adjustment pin is in the right place on the sleeve then slide the whole thing back in making sure to get the adjustment pin into the nob while sliding the sleeve an wick down
Dec 27, 2008 | Corona 23-DK Compact Heater
Wick
I must warn you, replacing the wick is a very tricky job. You should take it to the place where you buy the wick and let them install it.  Call first to make sure they provide this service.
Nov 09, 2008 | Corona 23-DK Compact Heater
Corona 23-DK Compact Heater Logo
54 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
