Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba RD-XS35 will not power on
I have recorded a few hours of old VHS tapes to the hard drive.
Disconnected the unit from power outlet for a few months.
Plugged it back in the other day and the green power on light would not
come on. Unplugged it ... let it set for an hour ... plugged it back in and
it still would not power up.
Any suggestions would be appreciated.
  • greg164 Dec 15, 2008
    Talked with Toshiba customer service tech reps several times and the only thing they could come up
    with was to send in the unit for repair.
    We tried several times to get the unit to power on with no success.
    I have NOT ABUSED THE UNIT IN ANY WAY to cause this problem.
    Have valuable recordings on the hard drive of this unit that I don't want to lose.
  • greg164 Dec 30, 2008
    Have unplugged the unit from my surge protector
    and plugged it directly into the wall outlet
    with no success.
    It was working fine the first dozen or so times
    that I used it.
    I unplugged it from the surge protector for a
    few months and then when I plugged it back in
    it would no power on.
    One thing about this unit I don't like it the
    fan always runs even after it was powered off.
    Novelist:
  • 163 Answers
K..Take a try—
1) Open your Toshiba HDD recorder and take off the board (main circuitry board).
2) Give hot air to the main board (If you have a hair dryer or else like it).
Note: the problem in HDD recorder is because the recorder not used…., and the main board condensers getting week.
Posted on Dec 30, 2008
    Guru:
  • 449 Answers
I know this may seem silly, but doing service work it is the first thing I check. Do you have power at the outlet? Try another appliance like a light. The breaker may be off.
If you don't have power, that is the problem.
    Genius:
  • 1,011 Answers
Sir,
Whenever the dvd player or electronic equipments which not be used for several months it going to be defective. You must at least use once in 15 days. The problem is yours not using the player for several months (how many months?) is something like fuse problem. Open the Player, check the power souce pin hole, near there is fuse like Red cap, open the cap check the fuse is ok or not. it may be burn. Also clean the lens using good Dvd lens cleaner. Open the player check the backside of the player there is wired with short circuit or sometimes the wires is cut off. check all the steps if it is not worked better go to customer support or manufacturer.
thanks
good luck
    Sergeant:
  • 306 Answers
 When it's not able to turn on, it misses it's schedule and doesn't record anything. pull the power plug out to get it to turn on again.even after tryin it the prob exists then contact a service center without any delay..
Posted on Dec 15, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, I would venture that it is a power supply problem. If after checking the external possibilities such as safety breakers, outlets, AC plug, master on/off, voltage selector (if present), then unit has an internal problem. Most designs for units such as this calls for a standby voltage that works just being plugged in. The output voltage for the standby is +5VDC and supplies the logic controller circuitry that eventually triggers the actual powering on of the rest of the unit when the Stdby/ON switch is pressed either on the remote or on the front panel.
If there is an indicator that power comes in such as a panel/button light, then the standby +5 is present, if none then internal diagnosis/repairs has to be performed.
This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 15, 2008
    Of course as a safety/back-up measure, the hard disk of the Toshiba RD-XS35 could be removed and backed up/duplicated using a computer.
    Genius:
  • 1,199 Answers
Press and hold power nytton for 10 seconds and that should reset it! there may also be a fuse inside of unit that has blown!
    Guru:
  • 859 Answers
Have you tried a different outlet?
Pressing all button on the interface?
Inserting a Tape?
Looking for a on/of rocker switch on the side or back?
  • Glenn Rogers
    Glenn Rogers Dec 15, 2008
    Do you have a local Computer Tech you can call upon?
    The ability to clone the hard drive in your unit exists. A computer tech can also look at your power supply. But, most of all they can get your data off the hard drive.
    Have the local PC guy look at this and do this task.
    Good Luck
While playing vhs tape, the sound is great, but the picture comes and goes.
That's usually dirty or worn out heads or not enough take up tension in the tape
Sep 27, 2014 | Toshiba RD-XV49DT DVD/DivX/VHS...
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Cant record from hard drive to dvd do i have to have a dvd ram?
No. You should be able to record stuff from the HDD to a blank DVR. I know it takes me quite a few tries before it actually works though. Very frustrating. Tell us what you're doing and what ends up happening and maybe we can walk you through it.
Mar 07, 2010 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
DVD unit says, disc is empty, with all DVDs inserted. DVDs are correct region and correct type, and they playback fine in other DVD units. I have already reset the unit per the Toshiba tech support site. I...
First, insert the DVD into the recorder.
Then, try double-click on OPEN/CLOSE button on the remote control. You have to make it very quick - two quick clicks on the same button. If done correctly, you will first see OPEN, then CLOSE in the right corner of the screen.
When done successfully, the unit will recognize the DVD again (if the burner has not failed totally.)
I tried that with RD-XS55 (it has the same DVD-RAM drive as RD-XS35.) It is not perfect solution, but it might help temporarily. In my situation, it bring my dvd drive back to "life," so I do not need to do double-click all the time.
Let's face it, your burner is dying whether you like it or not. And new replacement would cost you around $200.
Nov 06, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
After couple of hours unit shut itself down please help
in the manual it says the DVR will shut down after 3 hours of inactivity . The DVR should put up a message to " press enter " to reset .
hope , it helps .
Jan 20, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Will not power up but is still showing time
I changed my IR code by accident and now nothing works. I can not get back to the IR 1 code. Everytime I hit a button the DR3 appears but nothing works. How could I fix this.
Oct 01, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba dvd recorder #rd-xs35
The full manual can be downloaded from http://www.tacp.toshiba.com/dvr/product.asp?model=RD-XS35
The cable box hook-up is on page 22. There are two ways: 8bc47e0.jpg
Oct 25, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba tech support for this one. If it is not accepting the cleaner disk - you have to wonder if something is already intere or do you mean will not rune the disk? Inwhich case it is a drive failure and needs replacement[of drive if available] or whole machine. Contact Toshiba first though it may be a known issue.
Jul 05, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
