Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
What is an Info Code 21?
We have a bit of a dilema. Our UF-885 is displaying a "Printer Error Info Code 21" and I cannot find a description of this error anywhere. The manual doesn't note this code and I can't find anything on the net. The unit will not let us print any type of reports and we have possible orders in the memory of the unit. HELP!!
  • 3 more comments
  • jimoconnell Nov 09, 2007
    Also have an error 021 but replacing the fuser didn't solve the problem.
    Any ideas?
  • rockdr Apr 19, 2008
    Printer error info code = 021
    Panasonic UF885 Super G3
    No manual.
    Internet hunt begins now.
  • Anonymous May 21, 2008
    WHAT IS AN INFO CODE 016? THAT'S THE ONE I'M GETTING AND THEY DON'T LIST IT IN THE MANUAL.
  • Anonymous Oct 15, 2008
    haw can I do a lbp fuser reset?
  • ozkan60 Nov 20, 2008
    can you help me I have asame proplem Ican't fix.What is the clear problem.I need you please
    Sergeant:
  • 284 Answers
If you have replaced the fuser you need to do a lbp fuser reset. leave me an email and i will get back to you on how to do it.
Posted on Sep 22, 2008
  • Paul Homuth
    Paul Homuth Nov 20, 2008
    you need to do 2 things, lbp fuser reset and lbp error log clear.
    [[1]] function-7-monitor button 4 time. - the the * "start button"-should say service mode- then press 7 then press 1 start the use the arrows to scroll to lbp fuser reset adn hit start .. when done hit stop -stop
    [[2]] function-7-monitor button 4 time. - the the * "start button"-should say service mode- then press 6. then press-1-6- and clear the log .. hit stop - stop your done
I just had the same problem yesterday. Code 21 is not listed but in checking with a supplier it is a fuser that needs to be replaced. $175 for the part and $90 for service call.
Posted on Feb 15, 2007
I have the same problem info code = 21. any solutions on this? thanks
Posted on Oct 16, 2008
SOURCE:
Info Code 060 on our Panafax UF 885
Code 060 means that the toner door is open. Check the switches.
You might have to tape the door closed on the rear side or call a technician to replace the door.
Nov 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Our fax has the following error message: Printer
Press
Function
7
monitor key slowly 4 times
6
scroll sdown to SHIPMENT SET
set
wait for the machine to initialize
Nov 24, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634 on the Panafax Uf-885
No dial tone detected, make sure you are plugged into the LINE port.
Sep 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax uf-895 faxes, won't print. Put a new toner in, gives message 021
Error 021 relates to the Fuser unit (the bit that gets hot inside).
It is not related to the toner, which is a bit strange, but try switch off/on first.
Failing that you may need to clear the error in service mode. To access this:
Press "Function", "7", "Monitor" four times, then "*".
The machine should be saying "Service Mode"
Then press "7"
The machine should say "LBP Parameter Set"
(not 100% about the next bit but it should be reasonably straightforward to follow the display on the machine)
You are looking for "LBP Fuser Reset"..I think it is this:
Press "2" for "LBP Fuser Reset"
Press "Start"
The machine may reboot at this point.
If this is done correctly and the error still remains, the Fuser Unit will need replacing.
Sorry to be a bit vague on the instructions..not worked on these for a few years :)
Jun 19, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
What does the code mean? How do I fix it?
051 means the printer motor is abnormal. I would try replacing the toner cart then switch off/on in the first instance.
Apr 14, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634
Check your phone line by plugging a regular phone in.
Feb 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Feb 02, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
947 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
