Question about Samsung RS2630SH Side by Side Refrigerator
Samsung rs21dcsv refridgerator
After moving house it has taken us 6 months to re-plumb our fridge back to the water supply. Now that it is all plumbed in and a new filter has been fitted the water and ice have a nasty taste to it, im wondering if the pipes inside the fridge/freezer need cleaning? if so how??
    Problem Solver:
  • 16 Answers
THE PROBLEM CANT BE ON THE FRIDGES PIPES.THE PROBLEM MUST BE AT THE FILTER OR ON THE WATERSUPPLY.
Posted on Feb 23, 2007
How do I turn off the water to my icemaker on Kenmore Model 253.7818480 Refrigerator?
If your fridg is plumbed like most, there's a valve under your kitchen sink that controls the water going to the fridg.
Jun 12, 2015 | Kenmore Refrigerators
Water dispenser is slow
3 possibilities.
1. Water pressure is low going into the fridge- the way to test this is turn the water off, remove the line from connection in the back of the fridge and put it in a bucket to see the flow. The water should be shooting out with good pressure. If it is not, then you have a plumbing issue, likely at the valve under your sink.
2. Water filter is clogged- If your model has a water filter, it should be changed every 6 months.
3. Bad water valve. The solenoid valve in the fridge, right at the back where the water connects could be going bad and not opening all the way.
May 11, 2012 | Kenmore Refrigerators
I have taken the holdign retainer out of my moen 87440 but can't get the stem out please help
the stem is part of a cartrige its either brass or plastic covered with about 6 " O " rings. it gets corroded in place. moen sells a cartrige puller. see a plumbing supply house such sa HUGHES SUPPLY or Ferguson or o local plumber.
May 20, 2011 | Moen 87440 Single Handle Kitchen Faucet...
Water coming out of hose at home plumbing
Hello.Maybe the drain is blocked.it sounds like your machine is working ok to me,if you can hang the hose over the edge of a laundry tub & make sure the plug is out,see if the water drains away,otherwise it sounds like a plumbing problem not the machine.it started only after you moved houses so more likely the plumbing.hope i helped.
May 28, 2010 | Maytag HAV2557 Top Load Washer
Handle loose. I got to put in hard to turn the water on. look like miss a screw
This valve needs to be taken apart and lubricated with pure silicon grease (available at plumbing or builder's supply houses.) Good luck.
Nov 30, 2009 | Peerless Industries Peerless& Single...
How to increase the water flow from water dispencer on a FLSC238DSO when getting water it takes for ever to fill a glass
If your fridge has a water filter, you should change it every 3 months. An old filter can cause slow flow problems.
But it will never come out as fast as the kitchen sink. Depending on the location of your fridge, you have 10 to 25 feet of 1/4" pipe between your water glass and the high-flow plumbing, and water just won't move very fast through that.
Sep 16, 2009 | Refrigerators
Cannot remove water filter, will not unscrew.
You need a belt wrench.
06e.gif&h=74&w=155&usg=__rstarg_yfsch9ztqiidisf136tm=
This and other versions can be found at Auto parts stores and plumbing supply stores.
It wraps around the filter housing and applies pressure evenly over the whole surface to prevent breakage.
You may need to use large channel locks on the main housing as you turn the belt wrench to prevent breaking pipes if it is stuck really tight and you have plastic pipes.
Aug 26, 2009 | Frigidaire FRS26R4A Side by Side...
Admiral/Maytag fridge/freezer gc2227cdfb
no the water does not have to be plumbed in for the frige to cool. replace bulb. if short in the system exists then you will need to replace an interal wiring harness.
Jan 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Samsung RS2630SH Side by Side Refrigerator Logo
361 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
