Question about Mach Speed VENOM V2DP Motherboard
Onboard video not working
Onboard video stopped working on my V2DP motherboard. When I configure it as a second video on Windows XP it appears to be okay but wont send any signal to the monitor (new LCD). It used to work with CRT but I don't have it anymore to test. When I try to boot with onboar video the monitor receives no signal. Could it be configuration or is the onboard video gone? Many thanks, Mirco
  • Mirco Stefano Feb 13, 2007
    I configured the onboard video in the bios to be the primary video and even removed the video card (PCI). No signal is sent to the monitor even before Windows starts.
  • Charley Musselman
    Charley Musselman Apr 27, 2008
    Integrated video on V2DP motherboard failed without notice after 3 years. For 1000 days it worked fine, then it stopped entirely. I don't see how I could configure it to accept an video card without a BIOS menu. I guess I'll open it up and unplug unneeded boards and stuff. Who knows what the machine is doing? Updating Windows? Virus check? Anyway only way to stop is Big Red Switch...
    Scholar:
  • 155 Answers
If you install an AGP 4X video card the BIOS will give priority to your new card and it will disable the on-board one.
It looks like the on-board video is a weak part of this motherboard and it has failed to several people.
Posted on Oct 01, 2008
    President:
  • 2,961 Answers
If you have configured it to be the secondary video adapter in the bios, then it will not work as it has to be set as the primary graphics. the bios will still be looking for your AGP graphics card as the primary and bypass your on board graphics. If you need to use on board graphics, right click the graphics card in properties>hardware>device manager and select dissable or uninstall.
Posted on Feb 13, 2007
  • andrew pester
    andrew pester Feb 14, 2007
    If you are able,set the bios back to default.
    if still no luck, look on the mobo for the 'JBAT1' terminal and move the cap from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2.
    Start pc and when prompted to set up bios again set date and time and set to auto identify all drives and check the primary graphics, it should be set as onboard.
    Save settings and exit for a restart.
I am having some problems with my machine i have what i believe is a msi board with a phenom 2 quad core running 2g ram with a geforce 9600gt vid card . my problem is the vid card is great but of recent weeks it seems to be crashing and i get no further use from my machine unless i go back to mainboard video which sucks because it wont let me play games i have a 750w power suply so power isnt a issue i was thinking maybe i need to update bios and drivers and if so how do i find what is the correct ones???????? cheers
Posted on Jan 25, 2010
I tried an AGP card without success. Then I put a speaker on the motherboard and learned that I get no POST beeps. I concluded that the processor or the chipset had died, bought a cheap ($60) MB/Athlon combo from Microcenter and now have a computer maybe 10x the performance of the V2DP.
http://www.microcenter.com/single_product_results.phtml?product_id=0293652
If I have to replace $60 computers every three years, well, I can live with that.
cgmusselman
If mb work with crt and does not work with lcd then problem is in seting. Some new lcd monitors dosn't suport low resolucion 640 x480. From Leon
Posted on Sep 20, 2007
2 video card detected. onboard card are desable. PCIe card EN210GT. card detected first EN210 second 6150se MB MSI-7309 K9N6SGM-V
use your PCIE card to boot-up from CMOS, then check your onboard vga, try to configure it by 1st boot is your onboard, if that wont work then maybe your onboard vga was already damaged, better to use pcie video card rather than an onboard because it lets you consume the whole amount of your memory unlike the onboard card.. THanks
Aug 27, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
Sep 08, 2010 | ASUS P5KPL-AM SE Motherboard
What processor can i put in my jetway v2dp. I currently have an athlon xp 1660
Hello there burberryjam.
Here's your GEEK-steer ...
Per the manufacturer's webpage for its motherboard "V2DP", it will "...Support Socket-A for AMD Athlon /Duron TM uni-proccessor at 266/333MHz Front Side Bus with double data rate".
More specificically, here's its "CPU Support" list.
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Craig
Sep 25, 2009 | Jetway V2DP Motherboard
What is venom?
hi im josh in cebu phils . Venom literally means a poisonous substance in animals and plants but in PC it is only a code brand which means tough strong or powerful The V2DP is our newest addition to the Venom motherboard line. Mach Speed has taken one of our best selling motherboard, the V4MDMP, and made a low cost solution with a 333 Front Side BUS and 4x AGP slot producing an awesome all-in-one, low cost motherboard. The Venom V2DP is a very versatile motherboard on todays market. This feature enriched motherboard supports AMDs Athlon XP 333FSB processors, DDR 333 memory, and has a 4x AGP slot for High Performance systems or take advantage of the Integrated Video, Sound, and 10/100 LAN for a cost effective solution. The integrated UniCrome 64mg Video is ready for crystal clear DVD playback and high-resolution gaming. On Board 3D 6 Channel Sound will take full advantage of your high fidelity sound system and onboard 10/100 LAN is ready for broadband internet or a high speed network thats all hope i helped you.
Feb 26, 2009 | Mach Speed VENOM V2DP Motherboard
V2DP Video Stopped Working
It is not possible to disable the onboard video but, if you install an AGP 4X video card (Brown slot) the BIOS will automatically give priority to your new card.
Remember to remove the power cord before installing any card because the motherboard is still powered even if the computer if off.
Sep 28, 2008 | Jetway V2DP Motherboard
V2dp and geforce vid card
You need to re-install the motherboard drivers for the onboard devices.
Sep 01, 2008 | Jetway V2DP Motherboard
I need to purchase a jetway motherboard V2DP do you know where I can obtain one please
My old motherboard V2DP is dead, I need the exact same motherboard to replace my old one. If I can get the same motherboard then my main hard drive will think that its the old motherboard and then I can access my data files for MYOB and Windows XP, without reformating the hard drive I have none of the data backed up anywhere and can not locate my original XP Disk.
Jun 23, 2008 | Computers & Internet
Need help disableing onboard video, and installing PCIe video card.
Hi rebelel1271, I do have the manual for you're Intel motherboard. You can have it as well. Click on the link below to download you're manual. document.write("D101GGC Product Documentation & Manuals") D101GGC Product Documentation & Manuals
Intel states you do not need to make any bios changes when you add a PCI-Express video card. See this on page 17, PCI and PCI Express Auto Configuration. Before installing you're PCI-E video card, open windows controll panel. Than open add/remove programs. Look for the driver software for you're onboard ATI Radeon X200. Uninstall that software. (If listed). Close all opened windows & shut down windows. Unplug the power cord from the PC. Open the case. Install you're new ATI Radeon X800 PCI-E video card. Double check all internal connections, (In case you may have bumped loose any cables). You're X800 may also have a 3-pin or 4-pin male power connector built on the card. If so, plug power to the X800.
Intel D101GGC driver page.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21#DOC
ATI's web site for the latest driver's.
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
A little information. Once you're PCI-E has been installed. You're system memory will increase.
Good Luck!
If I can help you further, feel free to post here.
Mike
Jun 01, 2008 | Intel D101GGC Motherboard
Mach Speed VENOM V2DP Motherboard Logo
2,477 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
M_Butkus
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
