Question about Sony VPL SC50 Multimedia Projector
Temp/fan light Why does this light come on, how do i stop it ?????
  • tgrr Jul 31, 2008
    Hi...
         PLZ Help For sony projector vpl-sc50m
     Temp/fan light problem,
    How to Stop light.....
Hi...  PLZ Help For sony projector vpl-sc50m
Urjant.....
               Reply...
Posted on Jul 31, 2008
  • tgrr Jul 31, 2008
    Urjant.....
      Reply...
Cooling fan relay location for a 1992 corvet
the air con fan comes on with the air con switch. the engine cooling fan comes on when the engine temp. censer reaches operation temp. most times the air through the radiator when driving is enough to keep the censer cool and the fan not working if you stop at lights for any length of time it will come on.
Aug 15, 2014 | Cars & Trucks
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
Citroen C4 automatic. After car has been driving then stops, the fan keeps going until battery runs dead. The AA fitted brand new battery but problem persists. Any ideas?
Most "CCC" Or computer comand controlled vehicles supply power to the electircal components automaticaly via a relay, there will be one power source with the ignition off,& a second power sourse when the ignition is turned on,In this case the temp sensor will supply a ground to the cooling fan circuit when the engine temp reaches a specified temperature and the fan comes on. In my opinion you most likely have a relay that has malfunctioned(gotten too hot & fused internaly) find your engine cooling fan relay(s) & remove them.If the fan stops you may have found your problem.to check the power supplied to the relay you will need a simple test light, connect the clip to a good ground & probe the relay socket with the tip of the lights probe. where there is power the test light will light up. Ignition off-1 power source,Ignition on-2 power sources/ to check for the ground supplied by the temp sensor connect the test lights clip to a battary+ source & probe the relay socket again if there is a ground supplied the test light will light up, there may be more than one temp sensor in the cooling system.you should be able to aquir a wiring diagram online if you do not have a book.one of the sensors sends the temp signal to the gauge in the dash, & the other is the ground supply for thr fan relay. I hope I have been of some help.
Dec 15, 2012 | Cars & Trucks
When driving the cooling temp stays about around 197, but when i stop at a light, and go the temp, go up to about 222 and sometimes 230, and once the light turns green and you drive for awhile it goes back...
Sounds like like your radiator fan is not turning on when it should.Check fan relay,fan fuse and check for 12 volts at fan motor at connector.If all checks out then fan motor is most likely bad.
Apr 09, 2011 | 1997 Cadillac DeVille
2005 Kia Optima overheating during driving. Mostly when accelerating or going uphill. Fluid and coolant seem to be fine. Radiator fluid looks to be circulating to the thermostat when engine is at normal...
When the radiator fans stop functioning properly, the engine temperature will rise as there will be insufficient airflow to cool the radiator. The spike in temperature will be the highest when the vehicle is idling at a stop light or just stopped, but should subside once the vehicle begins moving again.
get the fan cked out.
Jan 21, 2018 | Kia Optima Cars & Trucks
Temp gauge increases when car sitting at stop light
Make sure your coolant level is correct first. Now you can start looking at the cooling fan as the culprit. Make sure it is coming on. Also make sure none of the blades or the fan shroud are damaged.
Sep 23, 2010 | 2001 Ford Focus
Will run for about 5 mins then fan will stop
It is OK for them to stop, a lot of cars get the fans going as a default, then once the computer checks everything, the engine temp is still low, the fans will shut off, and come back on when needed. Keep an eye on the temp gauge, and notice that the fans will come on when you stop at a light. Or city driving, they should never come on when cruising. And a lot of times they will run after you shut the car off. Just till the temp drops. Hope this helps.
Mar 21, 2010 | 2002 Mercedes-Benz C-Class
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
does it still in trouble? because I got your post today.
Jul 31, 2008 | Office Equipment & Supplies
Sony VPL SC50 Multimedia Projector Logo
919 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
