Question about Honeywell HE120 Humidifier
Motor turning real slow
I just installed he120 by pass humidifier upon start up motor turns real slow humistat is turned on to high and still same problem . this is first humidifier that i have installed and used so i do have some questions how fast should motor spin ? should motor spin when heating system is off ? how much water is sprayed into the heating duct ? will any parts or duct work rust from water ? thank you for your help pete @acelocksmith.com
  • cnearnest Jan 24, 2009
    My drum stopped turning as well. My humidifier is about three years old. I can't find a replacement motor or get any help from Honeywell at all. I do not know what a damper is--I'm pretty sure I don't have one and the owner's manual doesn't mention it. I am ready to disconnect the thing and forget about it.
  • zzz greg May 11, 2010
    Just spent 20 minutes discussing HE120 with Home Depot employee, including the question presented. The 24v power supply provided is always feeding juice to the unit regardless if blower is on. Consequently the wheel WILL be turning whenever the humidistat control is "calling", even if the furnace blower is off.
    I thought the main unit has to be mounted on the HEATED (supply) side while the duct hole is created on the (cold air) return duct. As shown in the following installation guide......
    http://www.appliancefactoryparts.com/con...
    Otherwise you will be forcing heated air into the humidifer (mounted on cold air return) if the round duct is installed on the furnace output duct, to be moistened and returned through the furnace, which the Home Depot employee said can create BIG headaches.
    Novelist:
  • 114 Answers
THE MOTOR ONLY TURNS THE SPONGE DRUM AT MAYBE 10X'S PER MINUTE. THIS IS A BY-PASS TYPE HUMIDIFIER THAT RELIES ON YOU FURNACE BLOWER MOTOR TO SUPPLY AIR ACCROSS THE SPONGE MEDIA. NOTICE THE 5"-7" ROUND HOLE MUST BE DUCTED TO THE PLENUM OR RETURN AIR. (IF MOUNTED ON THE PLENUM, THE HOLE HAS TO BE DUCTED TO THE RETURN AIR, AND VISA-VERSA.) CAUTION!!!IF YOU HAVE CENTRAL AIR? A "DAMPER" MUST BE INSTALLED AND KEPT CLOSED THROUGH-OUT THE "COOLING SEASON". SERIOUS DAMAGE TO YOUR COMPRESSOR CAN RESULT FROM TOO COLD OF AIR ... CIRCULATING AND "BY-PASSING YOUR EVAPORATOR COIL".
Posted on Apr 27, 2007
How do I wire up a Honeywell HE120 so it gets power only when the blower is on?
You didn't say what kind of furnace you have, but here is a link to what is known as an "air flow" switch that will allow the humidifier to operate only when it senses air flow through the furnace:
http://www.alpinehomeair.com/viewproduct.cfm?productID=453057513
Jan 26, 2015 | Honeywell HE120 Humidifier
Have a new evaporator to install, and directions on box say to "1. Note Humidifier Control setting and turn dial to "OFF" position." ... however, there is no dial, at least, not on the...
They are talking about the Humidistat which is separate to the Humidifier. Turn the power off to the furnace and that will disconnect any power to the humidifier. Turn the water off to the Humidifier if you have to remove it from the plentum. Then go ahead and install your new evaporator. If you are looking for the humistat follow the T-stat wire and see where it goes from the water valve of the humidifier...... But they may not have installed one and are useing a different way to turn the Humidifier on in the heating cycle.....
Feb 01, 2011 | Aprilaire 550 Humidifier
Humidity in my house seems incorrect i am using your he120
Feel free to respond as soon as you read this for confirmation. My responses will be provided often and quickly. Ensure that you read all the comments sent to you by me. I will read all your responses and comment from there on.
Jan 18, 2011 | Honeywell HE120 Humidifier
Output/Fan will not turn no matter what setting the speed control dial is on. Blue light and green light go on when humistat knob is turned. I purchased this humidifier in November and it was working...
Sorry to read about your problem, I hope this helps you out.
You either have a defective power switch, or defective motor, your unit is under warrenty, so I suggest you return it..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Honeywell HCM800 11 Gallon Humidifier
Humidifier drum Honeywell HE120 is not turning.
This happened with my humidifier as well. When the mineral deposits build up to the point where the drum binds, and is difficult to turn, the gears on the motor will strip. The clicking you hear are the ends of the stripped teeth of the motor gear rubbing up against the mating gears. Suggest you pull the motor - just remove the wire nuts from the control unit (replace wire nut over the exposed 24 Volt wire on each as you do this), then loosen and remove the nuts on the inside of the unit holding the motor. A number of manufacturers offer 'clock motors' than have a 1 rpm speed, and flat slot to receive the drum spindle. I used a Loeb motor which is commonly available in hardware stores, and had to insert a couple of small washers as standoffs, so the coupler was the right distance from the drum spindle. Reattach the controller wires, and you're done.
Jan 04, 2010 | Honeywell HE120 Humidifier
Honeywell HCM-646 -Motor not running
There is normally a capacitor to prevent surges across the motor it might the short circuit.# and preventing the motor from starting.
Jan 13, 2018 | Honeywell HCM-646 4 Gallon Humidifier
I have a Honeywell HE360A Humidifier and everything is installed now I am trying to wire it. The wiring diagram is very vague. Does anyone know how to correctly wire this? I have the humidifier, a...
Peice of cake: You run the white to sail switch the to common 2. Yrun thr re to humistat switch then to the white on the control board or conact us www.airenergyexperts.net
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
HE120 By-pass humidifer - Sponge Drum not rotating!!
Model HE908A drum is turning but we get no condensation
Dec 25, 2007 | Honeywell HE120 Humidifier
My aprilaire 600 humidifier stays on when the blower shuts off
Make shure the 24 volts is hooked up to power that is only powered up when the blower is running. Some furnaces have a HUM terrminal on control (make shure the HUM is 24 volts some are 120 volts then you must use the transformer supplied with the AP 600). You can use a RP # 50 relay that senses current only when the furnace motor is running on the heating speed. Hope this helps
Oct 30, 2007 | Aprilaire 600 Humidifier
Honeywell HE120 Humidifier Logo
489 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Christian Samuelsen
Christian Samuelsen
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
