Best Solution
posted on Aug 08, 2005
Beresford - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Using the 5/5/90 rule, your radio should last approx. 8-10 hours on a charge (exceptions do exist). 5/5/90 = 5% of the time transmit, 5% of the time receiving, 90% of the time standby. If you use your radio more often, your battery will run down quicker.
You may have a bad battery or poor charging habits. When you get a new battery you should charge it on a standard rate charger for 12-16 hours to fully activate the chemical in the battery. Once you have done this each subsequent charge should be after you have used your radio 8-10 hours or ran the battery down. Do not get in the habit of putting the battery on the charger when coming in for lunch or after using the radio only a few hours. This will cause air bubbles in the chemical, also known as "memory".
If your battery is more than 18-24 months old, you need to replace it.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Hnn NABC NABC LMR NIMH BATTERY MOTO
Email this problem
Email this problem
This Problem Also Relates To:
Audiovox FR14382CH (14 Channels) 2-Way Radio
Audiovox FR560FM 2-Way Radio
Audiovox 858811 (14 Channels) 2-Way Radio
Batteries.com 8148 Nickel Cadmium 2-Way Radio Battery
Batteries.com 9628 Nickel Cadmium 2-Way Radio Battery
Batteries.com 5453 Nickel Cadmium 2-Way Radio Battery
Batteries.com 5521 Nickel Cadmium 2-Way Radio Battery
Can you Help with these 2 Way Radios problems?
Repair Service
Find 2 Way Radio Repairman Near You:
