Question about Whirlpool Calypso GVW9959K Top Load Washer
Do you know the button sequence on a WHIRLPOOL CALYPSO which would check the washing, rinsing, spinning and draining cycles quickly? Saw a repair tech do it once.
    President:
  • Whirlpool Master
  • 2,651 Answers
If you remove the "emblem" from the front of the machine(very front edge of maintop assy.justs prys rigth off) behind it you will find a screw 1/4 inch socket. after removing hte screw the main top will pull foward slightly andthen lift backwards, under there glued to the inside front panle youll find a tech manual with all hte info on all testing procedures,uncliding hte "key dance" to get into different modes"
Posted on Dec 06, 2008
While in the rinse cycle, my Whirlpool Calypso GVW9959K Washer spins for a couple of seconds and stops, spins for a couple of seconds and stops. This process continues indefinitely. Wash cycle is fine and...
You need to change the computer board this is a common problem in the circuit board they now make the board with up graded circuits, I had to replace mine thats how i know about the up grade It's well worth the money. When I was having the trouble with ours no one knew what was wrong I even took it to a shop and they could not fix it they still charged me for the repair so i bought a used washer un-till i could order the parts my self , recieved the new board installed it and now works better than when it was new, my wife is very happy with it .
Aug 18, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Alarm which we do not have before. normal cycle. also on a rinse cycle. ocasionally loud banging noise.
You didn't mention if the machine was giving any error codes. Do the following steps to get any stored error codes and post them back to me.
Select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
Jan 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Code SL or 5L?
It is Code SL which means Suds Lock. Either you have too much soap suds for it to drain properly or Your drain pump is clogged and not spinning properly. Try running it through a rinse and spin cycle and if you still get a code (SL or Ld) then you will probably need to replace your drain pump.
Oct 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer off and on on the rinse and spin
there prob coins blocking drain pipe and cant 100% empty.
i had it with mine
Apr 15, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
At the end of the rinse cycle, water and suds will
Does water empty on spin? if not to check for blockage remove waste pipe from drain, place as low as possible into bowl, if water flows then fault likely to be on pump, if no water flows then pipes blocked and need to be removed to clear them. Good luck
Feb 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso clothes washer stuck on the "FL" for overfill code - will not reset after hitting stop/cancel or after unpluging - one year ago the customer service for whirlpool gave us the...
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
Jul 24, 2008 | Whirlpool Washing Machines
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Whirlpool Calypso GVW9959K Top Load Washer Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal De
