Question about SanDisk Sansa Clip MP3 Player
Mp3 player My mp3 palyer will not turn on at all.
  • 2 more comments
  • misfit666 Dec 12, 2008
    mine has done that twice to me now,it's only 3 days old, i have had it on before then i turn it off and nothing, it wont come back on,battery is fully charged! i plug it into my computer and still nothing!
  • bernzg Dec 14, 2008
    i have the same problem
  • Anonymous Dec 26, 2008
    me too!
    i just got it today,
    it wont turn on even when i plug it into the computer.
    god damn it. me too
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
New computer running windows 7, doesn't recognize mp3 player sansa clip when I plug it in. downloaded latest driver but wouldn't finish download because computer isn't seeing device.
Hi there,THe reason it isnt recognizing is becuase of your OS,windows 7 has porblems
recognizing devices such as your mp3 palyer...i reccomend redownloading the software driver and if all else fails return your mp3 palyer..
please rate me full... :)
Jan 22, 2011 | SanDisk Sansa Clip MP3 Player
MY MP3 DOESN'T CHARGE
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Mar 19, 2010 | Digital Audio TRIO MP3 Player
My philips mp3 is not switch on
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
Nov 27, 2009 | Philips SA4126/37 2GB MP3 Audio Player...
Mp3 player won't turn on
Jun 21, 2009 | iLO MP3 Player
MAGNAVOX 2GB MP3 PALYER
I have a magnavox mp3 player and it turns on and shows just the magnavox sign then shuts off what should i do
Jun 08, 2009 | Philips Magnavox
Usb is not recognised
you should turn the player on after connecting it to the computer.then it will be detected.previously it was not detected because you didn't turn it on.this should work
Jun 03, 2009 | SanDisk Sansa E280 MP3 Player
When I turn on the mp3 player, it says system is protected.
Try the reset. If that doesn't work download the Palyer Update from http://mymusix.com.
Feb 17, 2009 | MyMusix PD-6070 MP3 Player
My mp3 palyer
batteryh needs to be replaced
May 19, 2008 | Coby MP-C582 MP3 Player
Help
my coby mp3 player 2 gig has turned white the screen how do i unfreeze it?
Mar 12, 2008 | Coby MP-C7085 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
