Question about HP Compaq Presario V2000 Notebook
My compaq presario will not power up (no power). I have swapped and tried a different power supply. No luck
  • primeaujames Dec 06, 2008
    Thank you for the advise
    Jim Primeau
  • 24 Answers
Could be one of a few things. I'm assuming this is a presario laptop, not a desktop.
System needs to be restarted - Remove the battery and let the laptop sit a while (30 minutes). Reinstall battery and plug in power supply and see if it works. If not,
Remove the Battery and see if it is charged up (there are a set of green lights on most compaq laptop batteries with a spot to push to confirm the battery is charged). If it isn't charged, you very likely have a bad DC Jack connector on the laptop motherboard. If you apply pressure to the cord which plugs into your laptop (up and down, side to side) at the spot where the cord is connected (back of the laptop), see if the power light, on the front of the laptop, comes on for second. If it does, you can fix this by buying the DC Jack for your laptop model on ebay ($10) and removing the old connector and installing, soldering in, the new connector. This will require you to take your laptop apart. (note: Search the internet for the service manual for your laptop and this will give step by step directions on how to do this.)
Also, I think they do this at Best Buy (Nerd Herd) if you aren't comfortable doing ($75)
If it's not the DC Jack, it's a problem with the motherboard / CPU / Power Inverter or something else, most likely not worth your time to fix. You could sell the laptop for parts on ebay to recoup as much of your cost as possible, then buy another.
If you are slightly mechanical and are looking for a project and don't need the laptop immediately, you could buy the individual parts and replace piecemeal, based on directions from the service manual. FYI - I've picked up a few laptops for next to nothing and repaired this way {Compaq Evo n620c (CPU / DC Jack), IBM T22 (LCD Screen), Compaq M700 (DC Jack)}.
Posted on Dec 06, 2008
My presario 900 wont start
Either the motherboard is "dead" or the power-supply is "dead".
It's easiest to FIRST try a different power-supply.
Jan 04, 2014 | Compaq Presario 900 /1500 Series EVO...
Power not turn on
Try using different outlets.
If you have another Compaq Presario CQ60-220US swap the power adapters and see what happens.
Make sure that the battery is firmly seated.
-You may also want to try to turn it on with out the battery with only the power adapter connected.
-If it works without the battery I suggest to contact the manufacture for a replacement or order a new battery.
Ref: http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3860108
Dec 19, 2012 | Compaq Presario CQ60-220US PC Laptop
Green light flashing on compaq presario - computer will not turn on
You may have a 12V ATX line (6 wires) that needs to be connected to the mobo in addition to the main power (about 20 wires). Make sure they are both connected - try again.
Remove 1 stick of memory - try again.
Swap the stick you removed with the other stick and try again.
Unplug the power switch wires from the header on the mobo - try again - make sure you write down where each wire goes. Try again.
Swap the power supply with another ATX to see if it is the power supply (PS fail more than mobos due to dust buildup).
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
Aug 30, 2011 | Compaq Presario 5000 PC Desktop
I just installed a hard drive that I know works from a different computer, this machine is a presario sr1720nx. I get to the compaq screen and it reboots after getting to the recovery screen, I have tried...
If your HDD is being detected it is good. You did the right thing. There is a possibility that it could be the power supply. It is not providing enough power so the system reboots. If you have 2 HDD's connected try removing one of them. If your pc is connected to a power strip or a surge protector, try connecting it directly to the wall outlet.
Apr 21, 2011 | HP Compaq Presario SR1720NX (EL435AA) PC...
I HAVE A COMPAQ PRESARIO 5100 AND I CAN NOT START IT UP.I HAD A PROBLEM A FEW TIME STARTING IT WITH THE THE ON BUTTON BUT IT EVENTUALLY IT WOULD START. NOW IT WON'T START AT ALL.I HAVE A GREEN LITE ON NEXT...
take out the memory and try turning it on. If it turns on and beeps the motherboard is good but the memory is either bad or the slot on the motherboard is bad. Try moving the memory to a different slot.
Mar 28, 2010 | Compaq Presario 5000 PC Desktop
Hi any one help.. the problem with the compaq presario c300 is when i try to start it up the only response i get is the lights on lap top flash rapidly.this is the lights on the front as well as the...
the flash or blink codes you can log on to this site http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&product=3213867&docname=c01732674
and reference the blink codes. this is also the c300s service manual so you can go back and forth on other things. but if your swapping the motherboards then my suspect is your power supply. make sure that the C300 is getting 18.5 or slightly above if your on a digital meter. but if its below then it wont have enough power to turn on. speaking of power it could be the jack, the pigtails to the motherboard or a loose connector on the wall male end. so make sure to check your path of power from the wall to the unit. and follow electric guidelines and dont shock yourself. but what I used is a paper clip to put into the male end of the Dc voltand the inside is positive and set your ohm meter to DC 20 and it should read 18.5 v.
Mar 01, 2010 | HP 435768-001 - Compaq Presario C300...
Compaq Presario V2000 laptop stuck in hibernate or sleep mode. Power light, battery charge light and HD lights are all on, nothing on screen, no working sound of HD. I have unplugged/plugged, taken the...
Try booting into the BIOS Screen and resetting to factory defaults. If that fails suggest swapping the hard drive out and re-install the Operating System - Save your old data and migrate the data off the old drive. You can buy an external drive adapter to connect the harddrive to a USB port to migrate you data.
Good Luck!
Sep 09, 2009 | Compaq Presario 1275 Notebook
How to activate mute button in laptop compaq presario V6000
goto google enter "compact presario drivers" click on link to HP Support and drivers. once there, enter your product name/number. it should show you a list of all drivers available for your model. download your audio driver and reload it to your laptop. sometimes drivers get currupt and dont work right. hope this helps...good luck
Mar 18, 2009 | Compaq 220W Power Supply for Presario...
Dead compaq presario 6000
try a different power lead and if doesnt work it sounds like the power supply has blown, had it on a few pc's
Jan 13, 2009 | Compaq Presario 5000 PC Desktop
HP Compaq Presario V2000 Notebook Logo
109 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
