There is no sound on my pc
My speakers are plugged in right but no sound i don't evan have volume control in my pc
  • 189 Answers
When you dont see a volume control in your pc means that the sound driver was not installed have it installed using the cd installer you have.
thanks
Posted on Dec 06, 2008
The board don't any sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 16, 2011 | Computers & Internet
I am unsure as to when several of the problems I am having began, such as Windows Media Player now only running as administrator. After setting up the LogiSys SP6006CL LED speakers the LEDs would not light...
there could be many problems causing you sound problems
also
Sep 23, 2011 | LogiSys SP6006CL Clear 2.1+1 Multimedia...
My computer speakers don't work & i've tried everything even my headphones don't work so what should i do
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 27, 2011 | HP Audio Players & Recorders
My sound is not working
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Feb 26, 2011 | Computers & Internet
My computer have no sound
also
hope this helps
don
Feb 26, 2011 | Acer Extensa 4620 Notebook
No sound, tried another pc, unplugged, does not work. There is a puf sound when power connecting, it is as if the sound was stuck in a low volume. Is there anything else i can do? Thanks a lot
also
hope this helps
don
Feb 24, 2011 | Harman Kardon SoundSticks II Computer...
I plugged in power speakers (the cable green stereo plug which I plugged into the green inlet in the back of the CPU). I can see the volume level moving and I checked that it's not on volume mute) no...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
hope this helps
don
Feb 21, 2011 | Acer Aspire™ T180 PC Desktop
Speakers check ok, sound card ok, but very low sound from speaker even at 100%
also
hope this helps
don
Feb 17, 2011 | HP Pavilion a1730n PC Desktop
No sound driver
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
don
Feb 10, 2011 | HP Compaq d530 CMT PC Desktop
Search the audio driver for your PC in the HP home page by the model number and re-install it.
Jan 01, 2009 | HP Compaq JBL Pro (401508-001) Computer...
193 people viewed this question
 Grubhead
Grubhead
