Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Cuisinart cod-4000 powers up no brew
My cod-4000 powers up but it wont brew. Unplugged it for a few days and it worked - now it is dead again - any ideas?
  • Anonymous Mar 01, 2009
    cuisinart cod 4000 power up but no water gets to the coffee filter basket.
  • 8,596 Answers
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
Is there a fuse? How do I fix it?
It might be dead, but...
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place - especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement - call Cuisinart as they have a longer-than-standard warranty.
Feb 25, 2016 | Cuisinart Brew Central 12-cup Coffee Maker
We have a 2 year old Cuisinart COD 4000 series. The unit will no longer starts. We put on brew cycle and turn knob to on. Light comes on. Hear a click but it does not brew anymore. Have unplugged unit...
I just had the same exact issue, call cuisinart customer service and they'll replace it. The unit has a 3 year warranty, I had no receipt or anything and they are sending a new unit, all they ask is that I cut the power cord off of the old one and send it in.
Aug 07, 2010 | Cuisinart Programmable 12-cup Thermal...
Cuisinart COD-4000 Stopped brewing coffee; lost clock and timing
I have no solution, however I have the same problem. Wondering if you have resolved the problem yet?
Feb 16, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
My brew station is totally dead...no problems before now and is fairly new.
I have the same problem with Cuisinart COD 4000. I called the Service Department and will receive a new coffee maker.
Nov 29, 2009 | Cuisinart Coffeemakers
Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
Jul 15, 2009 | Cuisinart Coffeemakers
My cuisinart cod 4000 doesn't use the last 2 cups of water in the reservoir when brewing. Any ideas on what would cause this and how to fix it? It is less than 1 year old.
I would go ahead and clean the unit with vinegar and water - I would use 2 cups vinegar and 2 cups water, although the manual suggests 1/3 part to 2/3. Just brew the vinegar/water like it was normal coffee. Don't forget to take out the charcoal water filter, or else it will get soaked with vinegar. Also, make sure the 1-4 cup button is not pressed, if your variant of the model has a 1-4 cup setting. Good luck!
-Tha Mp3 Doctor
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
Nov 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Use Safety. Unplug. If You want to Handy Try, Open Bottom by removing Screws. Find ac Power cord wires and in loop should be a METAL small Tiny Protection Temperature Thermal Device that is Probally open. Your Local appliance place can sell you this as You need to get right temperature. Can Plug in Replacement or Twist with wires for support. Switch could be Intermittent ( Open ) also and a Replacement should Snap into Place and Leads attached as original or a safe way. A Simple Meter ( Harbor Freight ) Digital Meter only $3 will work for testing.
Aug 16, 2008 | Cuisinart Coffeemakers
Coffee pot not brewing
do you get any display?
Aug 09, 2008 | Cuisinart Coffeemakers
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
1,095 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
