Question about Canon Office Equipment & Supplies
My printer has the error code 6500 it is a canon mp450
  • Anonymous Feb 13, 2009
    What can I do?
    One minute it works fine and than a 6500 message occured.
    Now I can't doe anything with it
  • 837 Answers
Typically this is an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
If you want to take the time to try and repair it, you can take the unit apart and search for a loose connection, or unplug and replug all connections. Other than that, you should consider buying a new printer
Posted on Dec 06, 2008
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Posted on Dec 06, 2007
  • 37 Answers
SOURCE: Canon PIXMA MP450
An Error Message Is Displayed On The LCD title-bar.gif If an error message is displayed on the LCD, take the corresponding countermeasure described below.
Message
Action
There are no photos in memory card.
There are only invalid images on the memory card.
Photo data edited/processed on a computer should be printed from the computer, not from the camera.
There is no paper.
Reload the paper correctly and press [OK].
The paper is jammed.
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [OK].
Ink has run out.
U041
Replace the FINE Cartridge, and close the Scanning Unit.
If printing is not finished yet, just press [OK] on the machine to continue printing in the "no ink" state.
Replace the FINE Cartridge with a new one as soon as possible after printing finishes. The machine may be damaged if printing is continued under the ink out condition.
The following ink cartridge cannot be recognized.
U051
U052
U053
U059
The FINE Cartridge may not be installed properly, or the Cartridge may not be the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Some ink cartridges are not installed in place.
U075
U076
Confirm that the FINE Cartridges are installed in the appropriate positions.
The ink absorber is almost full. Press [OK] to continue printing. Contact the service center.
The ink absorber is almost full. Printing will no longer be possible once the ink absorber is full. Contact the service center immediately. Press [OK] to continue printing.
Incompatible device detected.
Depending on the model or brand of your device, you may have to select a print mode compliant with PictBridge before connecting the device.
You may also have to turn ON the device or select Play mode manually after connecting the device to the machine. Perform the necessary operations according to the instruction manual supplied with your device.
If the error is still unresolved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this machine. Use a digital cameras or digital video camcorder compatible with this machine.
Auto head align has failed.
Make sure all required boxes on the head alignment sheet are filled in, and that the sheet is set in the correct position and orientation on the Platen Glass.
If the machine is connected to the computer, you can align the FINE Cartridge using the MP Driver. Follow the procedures described in the Printer Driver Guide.
The following ink may have run out.
U162
This FINE Cartridge may have previously been used, or the ink may have run out. The function for detecting the remaining ink level will be disabled since the remaining ink level cannot be correctly detected. If you want to continue printing without this function, press [OK]. Canon recommends to use new genuine Canon Cartridges in order to obtain optimum qualities.
U140
The FINE Cartridge may not be the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Printer error.
An error requiring servicing might have occurred. Turn OFF the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn ON the machine. If the same error occurs, contact a Canon service representative.
Posted on Jun 08, 2008
  • 300 Answers
SOURCE: my canon mp450 printer always show 5010 error code
Try this from the support site. Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Posted on Jun 05, 2009
cene765
  • 787 Answers
SOURCE: canon error code 6500
It's a hardware error.Your printer need service.
Posted on Oct 08, 2009
komguy
  • 2306 Answers
SOURCE: Error code 6500
That's a strange error for that machine, a network error? I would try removing the printhead and see if the error changes to printhead not installed, could just be a defective printhead which can cause strange errors.
Posted on Dec 28, 2009
I have Canon Pixma MP450, the error is 5B00? how to Fix it? Now cannot use the printer due to this error. Thank you for your attention
Error 5B00 means that your ink absorber is full. you need to reset the counter protection and replace the ink absorber inside the printer.
Visit the link below for instruction on how to reset the canon mp450 printer EEPROM
http://pcmediks.blogspot.com/2010/09/how-to-reset-canon-mp450-printer.html
Dec 09, 2010 | Canon Pixma MP450 All-In-One InkJet...
Turn on and error 6500 displays? How to fix?
The Service Manual for the MP500, which is very close to the MP450, indicates that the error code of 6500 is a PCI buss error and this is a Service Error Code. Typically this is an internal error of one of the ASCI chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
If you want to take the time to try and repair it, you can take the unit apart and search for a loose connection, or unplug and replug all connections. Other than that, you can sell it for parts.
Good luck
Aug 11, 2010 | Canon Pixma MP450 All-In-One InkJet...
My new canon pixma MP450 has an error code of 6500 on the display panel. Can you please tell me how to fix it
this is printer logic motherboard problem
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 13, 2010 | Canon Pixma MP450 All-In-One InkJet...
What does error 6500 mean?
6500 mean hardware error.In most case error in logic board assembly.Sounds like you need a new printer.
Nov 03, 2009 | Canon Pixma MP450 All-In-One InkJet...
Error code 6500
That error is an error processing on the main logic board, Canon suggests you replace the main logic pcb.
Aug 24, 2009 | Canon Pixma MP450 All-In-One InkJet...
Error Code 6500
Isto é causado pela informação em seu registro. Refira por favor a seguinte ligação e transfira o cuidado avançado de Windows… que você não será… varredura disappointed com AWC e não tentará sua impressora outra vez. A mensagem indicada é um erro, mim está supor. http://www.iobit.com/advancedwindowscareper.html
Apr 11, 2009 | Canon Pixma MP450 All-In-One InkJet...
Pixma mp450 error 6500
what this solution, for error code 6500, please, answer in portuguese, thank you
Jan 26, 2009 | Office Equipment & Supplies
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Hi, my canon pixma mp450 is not feeding the paper thru properly.
We had the same problem so we opened the screws up at the back, gave it a shake and suddenly a asweet wrapper appeared. We then put the screws back in and it started printing again! Good Luck!
Jan 16, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon printer displays error
CANON
PIXMA MP450
Sep 18, 2007 | Canon Pixma MP450 All-In-One InkJet...
470 people viewed this question
old marine
old marine
Corne Viljoen
