Question about Kenmore 24032\24036 Top Load Washer
Washer full and then stops and gives a beep while flashing F 51
Washer is a little more than a year old - Kenmore Elite Oasis - top loader.  While washing load - after 5 -1 0 minutes it begins beeping and flashes the F followed by 51.  What does that mean?  Help!
  • Anonymous Mar 28, 2014
    Washer stopped and showing F 51 code
  • Anonymous Mar 29, 2014
    lights flashing and beeping
  • 20 Answers
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Posted on Dec 08, 2008
My top loader Kenmore Elite Oasis HE washer displays F 51 error ?? Any ideas and suggestions on how to fix this
F then 51 flashes when there is a motor rotor position sensor. Captain we have a problem? What is now Spock? More primal urges? Worse captain! Engines overheating. Spock can you pinpoint the source? Yes Captain: Abnormal activity within the wash water. What? Suds detected. Computer report. On board sensors have detected suds sir. They have made several attempts to clear up the situation by running extra rinse cycles!. As a result RPS has overheated causing engine failure. What will we do Spock? Capatin we need to See TEST #3, Page 10.
Apr 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I OWN A KENMORE ELITE OASIS HE TOP LOAD WASHER AND I AM HAVING PROBLEMS WITH RUNNING A FULL CYCLE WITHOUT HAVING TO ADJUST THE LOAD A F 51 CODE APPEARS AND THE MACHINE STOPS. PLEASE TELL ME WHAT I NEED TO...
F51 MEANS BAD READING ON THE RPS SENSOR. COUPLE OF THINGS YOU NEED TO CHECK. IT'S A LITTLE COMPLCATED. IF YOU ARE A LITTLE MECHANICALLY INCLINE, I CAN WALK YOU THRU IT WITH WITH NO PROBLEM
BOYNISMO@YAHOO.COM 714-334-1998
Dec 06, 2009 | Kenmore Elite HE4 Electric Dryer
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis
You want to charge me to get answers from you but you want me to tell you my fix for free???!!! I don’t think so!!!
Aug 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
635 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
