Question about Sony NW-E405 MP3 Player
Hypson mp3 player
I have a new hypson mp3 player but when i try to use it, the screen said, key locked. can u tell me why and what should i do
0 characters
1 Points
My son forgot his password to his GoGear connect 3
If he speels like you I can understand :) Turn off player, get Philips Songbird and go to TOOLS and then RESET MY DEVICE choose your device. Screen will then tell you to hold vol+ key and plug in device to USB. You will loose everything but it will get rid of the password lock.
Feb 15, 2012 | Philips GoGear HDD1850 MP3 Player
MP3 player GHT D2000 appears locked
hi shreejit here try to reformat the mp3 player so the code will be unlocked and u can use your mp3 player in a normal state
May 31, 2009 | MP3 & Digital Media Players
Sansa e260, key locked
I'm not familiar with SANSA but try this.
try to locate any slide switch from your MP3 player indicating
"HOLD" or a picture of a "lock" or a "key" then switch it backwards.
and in some cases this switch can also be locate at the headset unit if the headset does have a control buttons on it
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
My RCA TH1161-A mp3 player wont work at all
Ensure the key lock is not activated by sliding
"Power on/off ( )/Hold" towards the center
position. If your player isn’t already on, turn it on by
sliding "Power on/off ( )/Hold" to the left
and holding until the player turns on.
-Tha Mp3 Doctor
Jan 06, 2009 | RCA TH1101 MP3 Player
Key locked system shut down
On the top of the player there is a slider. When it is showing orange next to it your player is "Locked" so accidental button pushing wont mess up your tunes. Slide it over so it shows only white instead of orange and your player should be just fine.
Jun 18, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 it doesn't work
chech out for the lock key at he top at side of the earphone port.. it is lock key move it to unlock
May 09, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 player says key locked system shut down
I had this same problem on another RCA player.. with no instructions manual it was hard to figure out what keys locked meant. Then I noticed a little slider on the side of the player, it has a little icon of a pad lock on it. Once I slid this back, the keys lock problem went away and I was able to listen to my music once again.
My best guess of what keys locked means.. you don't want you mp3 player to turn on when you put it in your pocket with your keys, so you change the slider to be locked, when your sit down and your keys are pressing against your on button, the mp3 player will shut off... as we all have experienced in frustration.. saving your battery.
Perhaps RCA should make this slider bright orange so it pops out and does not blend in so much, or they should put it right next to the on button.
Apr 30, 2008 | RCA OPAL M4001 MP3 Player
Please help me
You have the locking button activated. Deactivate the button and it should turn on normal.
Feb 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E 260
You have locked the keys, look for a switch with a red , white or orange lock icon and move it then try to turn it on. The switch should be on the side of the player, either at the top, bottom or sides of the screen.
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
Sony NW-E405 MP3 Player Logo
129 people viewed this question
Top Sony MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Sony MP3 and Digital Media Player Expert? Answer questions, earn points and help others
