Question about HP xw4600 Workstation Linux Installer SATA-SAS PC Desktop
Xbox 360 wont display apicture
When i turn on my xbox 360 all 4 quadrants flash green on xbox and controler then after about 5 mins it turns off. I have gone througth the usual checks and also reset controlers and change leades but still the same. please help
Try pressing the small button on the xbox (control locator) and then press the tiny button the top of the control to sync up if its wireless. Otherwise change the battery check the cables then proceed to the hammer.
Posted on Dec 06, 2008
Xbox 360 controller not working, all 4 lights are blinking.
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
Jun 06, 2010 | Microsoft Xbox 360 Controller
My controller just shows all four lights flashing and when i try to sync it, the lights just keep spinning round and does'nt connect
Jun 03, 2010 | Microsoft Xbox 360 Controller
Game loads okay but controller does not work. controller is brand new. lights work on controller but can not ply any games
If the controller is brand new, you need to Sync it with your XBox 360.
Turn on your 360 using the button on the console.
Turn on the controller by holding the X button in the middle.
With both on, click the SYNC button on the xbox 360.
Then click the SYNC button on the Controller.
The green ring around both should flash a few times, then the upper left quadrant should light up on both meaning it's Sync'd.
Enjoy.
Mar 17, 2010 | Microsoft Xbox 360 Wireless Controller
I cant get the xbox to work from the controllers, when i press the "x" button on the controller it just keeps flashing and doesn't allow me to link up with the console
The "x" button is the xbox guide button that is in the center of your controller.
1. First, turn on your console by pressing the power button on the console itself.
2. Next, press the xbox guide button that's on your controller. (The button that lights up and flashes when you press it).
3. On the front of your console, just to the right of the memory card B slot & just below the right corner of the DVD tray, there is a small, round connect button.
4. With the both the console & the controller on,(lights flashing) press and release the connect button on the console first.
5. Then on the controller, press the connect button (green arrow, circled in red) that's between the Left Bumper button (LB) and the charging port (blue arrow).
6.The lights on the controller and on the console should continue to go in a circle and stop.
7. The upper left quadrant is controller # 1, the upper right quadrant is controller # 2, bottom left is # 3, and the bottom right is # 4.
8. Once the controller connects the the console,you're all set. Then the next time you go to turn it on, just press the xbox guide button on the controller and it will turn the power on to the console for you.
9. If you ever take your controller and use it on another 360 console, you have to go through the same connection steps as you just did. And then again, when you get back to your console
Hope this helps! Happy gaming!
Dec 17, 2009 | Microsoft Xbox 360 Console
Ring of light has 4 quadrants flashing green - no picture on TV
Red Lights are a problem for Xbox 360, however green light problems are hard to find, still you can try following steps to check where the problem lies
1) Boot with no HDD and see if that helps.
2) Also remove all your inputs in the back, and reinsert them. Make sure your HDMI/VGA/Compenent input is plugged in correctly.
3) Try switching the output from HD to SD, if you have a HD VGA Cable for your Xbox 360
4) Turn the Xbox 360 off, turn it on with the controller, as it turns on hold the Y button and the Right Trigger, this will put all audio/video settings to default.
If the above given steps do not help, kindly call Microsoft Support and try to get an answer from them to this issue, and if required you may have to send your console for repairs.
Dec 07, 2009 | Microsoft Xbox 360 Console
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 problem
Try this:
1. Remove any discs from the disc tray. 2. Turn the console off. 3. Turn the console on.
Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller. Make sure that you use the player 1 controller when you do this. The player 1 controller will have the upper-left quadrant light illuminated. 4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. 5. The Xbox Dashboard resets the display settings to the default settings, and then automatically restarts the console.
Mar 25, 2008 | Microsoft Xbox 360 Console
New controller purchased flashes green contantly and no quadrant is assigned
post this under xbox 360, it's in original xbox right now.
Nov 18, 2007 | Microsoft Xbox Console
HP xw4600 Workstation Linux Installer SATA-SAS PC Desktop Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
