Question about HP DeskJet 722c InkJet Printer
Printer stopped printing and says its off line!
How do I get it back on line?
    Guru:
  • 731 Answers
HI,
Im Rizwan from India, i would to tell u to check few things that will resolve this problem
SOLUTION:
NO 1: Check the Connection and power
1.Check the USB cable and the power line to the printer.
2.unplug and replug the cables at the PC an printer end.
NO 2:Check the printer status in control panel.
1.Click start - >Run.
2.In the run window type "control" (without quotes).control panel will open.
3.In the control panel, look for printers and fax and check the printer icon.
4.If printer icon says Offline, Right click on printer icon and select "use printer online"
5.Try printing, if it didnt print follow step NO 3.
NO 3:Restart the USB Composite Device.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET 720C
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Try printing Now, if it didnt work please response.
Thank you
Rizwan
rizwan84tx@gmail.com
Posted on Dec 06, 2008
T6215 stop to print at 2000 lines printing
That suggests it has the wrong driver or either the printer or the computer needs more memory
Aug 04, 2016 | Tally T6215 Matrix Printer
Printer prints one line, then alarm light comes on and stops printing.
Sir the printer is giving line because the cartiage or toner is not of good quality so it does not melt properly and produces line while the alarm comes and stop printing is due to the problem in charging cathode or gutter
Jun 03, 2013 | OKI MICROLINE 321 Turbo Matrix Printer
How to stop the stop the printer into moving to the next page after printing a single line
set up the page length to desired length on the computer where the printer is installed.
Oct 26, 2012 | Panasonic KX-P1150 Matrix Printer
Black horizontal lines
Put the old cartridge back in. Print a page. If the lines go away, get another cartridge.
Oct 15, 2009 | HP LaserJet P3005n Printer
Hpd4160 printer yellow light keeps flashing, status, "off line"
See this notice about the flashing light. Then see this article, particularly step 4. You may need to clear the print queue & restart the print spooler. Make sure you reboot your system. If that doesn't correct the issue, try a power reset as described here before uninstalling or reinstalling the printer software.
The printer uses your system memory to print from, and communication glitches do occur.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 06, 2009 | HP Deskjet D4160 InkJet Photo Printer
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
Faint one inch wide line appears at the same time, every time.
We've seen this problem in our shop. The document is "timing out" and the gap is where it restarts. You have to set the print manager to wait to print until the document is finished processing. Any large print will do the same thing. Try "pausing" the printer on your computer, then execute the "print" command in Photoshop, then go back to the printer control panel and "un-pausing" the printer.
Apr 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
Verifone 250 printing letters and numbers will not stop
The letters and number it is printing is the self test print mode. Normally to run the self test you would turn the printer off, then hold down the feed button, then while holding the feed button, turn the power back on. It sounds like your feed button may be stuck.
Mar 10, 2008 | VeriFone 250 Matrix Printer
HP DeskJet 722c InkJet Printer Logo
94 people viewed this question
Ben Johnson
