Question about Onkyo Audio Players & Recorders
The only display on my onkyo 706 is fl and fr. But all other speakers have sound.
When i played a dvd later that night the c lit up. And dolby digital was available. (I have my dvd optical cable hooked up to my receiver.) I still don't know why they put boxes with no letters in them.
Yet sound still comes out the speakers.
I really thought this receiver was hook up the speakers plug in the mic and your ready for sound.
So i have more questions. i am just trying to work one bug out at a time.
Thanks.
Jim
Posted on Dec 06, 2008
I hv a Denon AVR 3805, i tried to set it up but after doing all the necessary, i found out that it was only running on 3 speakers (FL,FR & SW). I did connect the center speaker but the sound just...
SW means sub woofer, not necessary means center speaker in all receivers. Instead of setting 5ch stereo, if you have 3 speakers. try to set "3channel" or "simulated". If you own more than 3 speakers, you may refer to the userĀ“s manual to correctly wire them to get the full sound.
Sep 18, 2010 | Denon AVR-3805 Receiver
Whats the radio wiring color code. trying to install a radio to a chevy astro van 1997
Hello!
POWER: Orange=Constant +12...Black=Ground
Yellow=Switched +12
SPEAKERS:
FR + Green
FR - Black (common ground)
FL + White
FL - Black "
RR + Dark Blue
RR - Internally grounded
RL + Brown
RL - Internally grounded
Guru............Saailer
Apr 08, 2010 | Car Audio & Video
I need the wiring diagram for a toshiba tx-904 compact disk player / receiver
red ignition w-fl speaker(+) w/b-fl speaker (-)
gray-fr speaker (+) gray/black -fr- speaker(-)
yellow-constant 12v(+)
blue motor antnna
rca gray-rear left - rca black rear right
black ground
Aug 22, 2009 | Toshiba Car Audio & Video
I have a onkyo 706 reciever and I can't get any TV sound
Component (i.e. TV) should be connected to plug labeled IN (signal IN receiver).
Jul 15, 2009 | Onkyo TX-SR606 Receiver
Can the speakers be used with other Receiver? Like an Onkyo 706 for example. Thank You
Yes you can use the speakers and also the sub if it is a powered sub with a phono input,but be aware they are nowere near good enough for the Onkyo 706,look at the JAMO 102 sub and sats as a starting point if you have a small room,say 4meters x 5meters,or somthing from other good speaker companys to make the most of what is a hard hitting amp,but if you must use the speakers you have set the cross over to about 120hrtz to save the main speakers getting to much bass .
Hope this helps.
CABLE GUY.
Apr 20, 2009 | Sony DAV-FR10W System
Receiver - onkyo tx-sr606 problem - in the setup menu screen, option 2 "speaker setup" isn't highlighted to select like the rest. I am setting up new speakers and want to adjust the dB on a single speaker,...
if the speaker settings are deactivated, there is no other way but to reset the receiver back to factory settings. press and hold down vcr/dvr and then press standby. you will the word reset and that should activate your speaker set up again. hope this helps. ^_^
Dec 06, 2008 | Onkyo TX-SR606 Receiver
Speaker is not detected
If you are connecting a 5.1 surrround sound rather than 7.1, have you connected the surround speakers to the surround left and surround right rather than surround back left and surround back right?
Nov 11, 2008 | Onkyo TX-SR703 Receiver
I have a pioneer deh-p44 car stereo and need to know the specifics on the wires.
The wiring colors are the same on all major brands of head units it goes a following:
Red: swtiched +12
Yellow: constant +12
Black: ground
Orange/white: dimmer
Yellow/black: cell phone mute
Blue/white: amp turn-on
White:FL speaker +
White/black:FL speaker -
Gray: FR speaker +
Gray/black:FR speaker -
Green: RL speaker +
Green/black: RL speaker -
Violet: RR speaker +
Violet/black: RR speaker -
I hope I could help. Good luck
-Andrew Hawkins
Sep 03, 2008 | Car Audio & Video
Need color codes and wiring diagram for a 2003 Pioneer DEH-P6500
Red: swtiched +12
Black: ground
White:FL speaker +
Gray: FR speaker +
Green: RL speaker +
-Andrew Hawkins
Aug 20, 2008 | Pioneer Car Audio & Video
No sound in surround modes
I just connected the front main speakers and sound well, but when i connect the speakers (2 fr, 2 rear, 1 ctr) there`s no sound in any surround mode from any source.
Aug 15, 2007 | Onkyo TX-SV525 Receiver
71 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
