Question about Husqvarna Chain Saw 20" Bar
How do you take apart the crankcase on a Husqvarna 50 chainsaw?
Take regular screw drivers and pound them in a little with a hammer and then pry all the way around till it comes apart.
Posted on Dec 06, 2008
  • 211 Answers
Hi Remove the spark plug,fan housing and chain cover.Enter in the spark plug hole a piston blockator (a rope with many nods) and block the piston in the cilinder.Remove the clutch clockwise and the flyweel counter clockwise.Remove the air filter,the cover,the mufller,the carburator,the handle,the gas and oil tanks.Locate the 4 screews to remove the cilinder .Remove the oiler and the worm gear.At the clutch side are the screws to separate the crankcase.
best regards savumihai71
2 Suggested Answers
  • 398 Answers
SOURCE: Spltting a crankcase on a Husqvarna 394 chainsaw?
the gasket is what is holding it together, if all the bolts are off. you gotta peel it apart. put one side in a vice is how i do it. and do it slowly. everything should slide out .im just telling you from my memory and i cant visualize that particular engine at the moment.
Posted on Mar 13, 2009
I HAVE A RANMCHER 455 HUSQVARNA IT DOESN'T SEEM TO HAVE ANY COMKPRESSION
You stated that you checked the compression, How many pulls on the starter to get 50 PSI?
Also some shops check compression, way to quickly like pulling on the cord one time and then saying yup, No compression. There are a number of other things that it could be, like maybe the de-compression valve is not working or you have a crankcase seal leak.
Anyhow, If you put the correct fuel and oil mixture in the engine, I seriously doubt that there is anything major wrong with your saw
Dec 10, 2016 | Husqvarna Garden
Hto remove crankshaft seals on a husqvarna 136 chainsaw
You will fully disassemble the engine as you must the cylinder from the crankcase. Husqvarna only sells the seals with the bearings they must be pressed on to the bearings. Since the 136 uses the same bearing set as the 141 you can order a set seals for the 141. In this the old seals must be pressed off first.
Here is a link to a site that sales the 141 seals.
Husqvarna oil seals set fits 36 136 141 142
Dec 21, 2014 | Husqvarna Garden
How do I know if my husqvarna '51' has a 44 or 45 mm piston..Does it matter if I need a cylinder kit too...
The 50 had a 44mm piston, all 50 specials and 51s had a 45 mm piston, as a cylinder and piston both will fit the crankcase, the stroke was the same on both.
Jul 29, 2011 | Husqvarna Garden
Inherited an older husqvarna chainsaw 50 rancher. Going through it see the start switch has only the wire from the ignition module going to the terminal on the switch...no other connection. Is the other...
If it is an early 50 the sides of the switch are metal, so this creates the earth, the later machine has a plastic switch, this had an earth tag on the switch, which sat on the top of the crankcase and was secured with a self tapping screw, this also held the switch in.
Jul 04, 2011 | Husqvarna Garden
Hi. Is it possible to drill & tap the raised round boss on the crankcase casting of a Husqvarna 272xp chainsaw & fit a decompressor. I really struggle to overcome the compression to start this saw....
Absoulutly not, this will end in disaster, try fitting an additional cylinder base gasket, and move the ignition module out to 0.5mm, make sure you are useing a 50-1 fuel oil mixture, i have done this many times and it will make things better, good luck.
ADW
Dec 20, 2010 | Husqvarna Chain Saw 20" Bar
In what order is a chain tensioner installed on a 266 XP Husqvarna
The tensioner is in the crankcase, insert the screw through the hole in the crankcase, thread the square plastic block onto the screw followed by the metal adjuster pawl, the plastic block shold come all the way up the thread and lock into the recess in the screw.
Nov 24, 2010 | Husqvarna Chain Saw 20" Bar
I have a Husqvarna 55 chainsaw that has a crack in crank case
YOU MAY BE ABLE TO GET THT ONE WELDED WITH A TIG
Jul 27, 2009 | Garden
Mar 12, 2009 | Husqvarna Chain Saw 20" Bar
Chainsaw Service manual for Husqvarna in New Zealand
here's a Contact in your Area:
Husqvarna New Zealand 15 Earl Richardson Avenue, Manukau City Auckland
Auckland
New Zealand
Tel: +64 9 920 2410
Fax: +64 9 920 2429
Web: http://www.husqvarna.co.nz
E-mail: carol.osborne@electrolux.co.nz
Nov 17, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
201 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
