Question about Seagate Barracuda 7200.7 40 GB Hard Drive
No power on psu when Hardrive connected
There is no power when I connect my Seagate 120gb hardrive. I use another drive and it works fine. I think my 120gb hardrive got grounded on power signal... does anyone experience this..
    Novelist:
    Champion:
  • 202 Answers
Yes, I actually experienced it too about 2 months ago. I believe there is short in the board. I have a 200gb barracuda that failed (too soon) and I swapped the boards...just to see what would happen. I was able to recreate the other drives problem and vice-versa. I think if I could get my hands on a working barracuda(if there are any) I could recover my info. curse of the 7200.7's Good Luck, Tim
Posted on Feb 15, 2007
SOURCE:
I connect my seagate external hardrive to my xbox to store some data on it because my xbox does not have an internal hardrive. So i figured i can use my portable external hardrive to my xbox, and it said i...
Either you have 50 gigs of stuff on there or your hard drive space is not being properly read. U might need to reformat the drive if necessary.
Meanwhile your xbox electronics may have a limit on the size of space - so if the drive has 200 gigs of space on it and your unit will only recognize 32 gigs, then that is all it sees and can use. Capiche?
Jun 16, 2017 | Seagate Computers & Internet
The light on the hardrive is blinking faster than normal and i couldnt connect to my laptop, it was working fine 2 mins before, i think its because i forgot to safety remove before i plug out.
This kind of behavior of a Portable Hard Disc, may be due to some reasons :-
Most probable cause is the Virus / Malware in the PC or Laptop.
Second cause is USB slot of PC or Laptop is corrupt or not properly installed.
The last cause is the Data Cable is not right.
Mar 12, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
Externalseagate 250go not open how to solve
If you cannot open or see the harddrive when you connect it to your computer after it is powered on then that is the external harddrive itself. First, check if the power connection is connected and the usb cord connect correctly. Then see if any lights come on on the external hard drive. If lights does come on and still nothing showing or coming on to the computer, then your harddrive is history. Seagate makes one of the worstest hardrive. You can google this up about seagate promblem and there are thousand out there who have this same promblem. I know this because I have the same promblem you have.
Jan 17, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
When I attach the transfer cable to the 120GB hardrive it only shows it as a usb drive with 16GB of space. I checked the hardrive on my computer and it shows 120GB of space, how do I get it to show as a...
16 GB is the maximum USB storage the XBox will allow, but you may have up to two devices connected at the same time (which means nothing for your current situation, sorry). This is Microsoft's way of saying you should've opted for the larger internal hard drive.
Jan 01, 2011 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
Seagate Barracuda external hardrive - damage to usb connector on
Assuming the drive itself is still ok (it sounds like it would be), then yes, you can put the drive into another case or directly into the motherboard if you know how to do that.
May 27, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Problem hardrive barracuda 7200.7 160G: the led
I am thinking external HDD?? Bad power supply or check the connection.
Jul 19, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Archos AV500 / USB harddive
from what i gathered with my archos 5 it is due to a power issue so the archos does not provide enough power to make the external hd work
Mar 08, 2009 | Archos 605 WiFi Digital Media Player
Seagate external hardrive
Here is the link to the Seagate's utility tools: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Downloads&vgnextoid=51e092db8a13d010VgnVCM100000dd04090aRCRD The links that you are looking for are DiscWizard and SeaTools. And if you have just lost it, here is a recovery program that you can use: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
Mar 20, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Seagate Barracuda 7200.7 40 GB Hard Drive Logo
121 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
