Question about Sony Handycam DCR-TRV120BT Digital Camcorder
Sony TRV120 Won't load tape C21:00 code
Good Afternoon.
We have repeatedly tried to load a tape in the Sony TRV120 Camcorder but it flashes C 21:00
We cannot find the Users manual online does anyone know what the difficultly is?
  • Anonymous Jan 13, 2009
    Similar problem. Also, won't eject 50% of the time, the tape mechanism only comes out partially. Also, the lcd has a eject icon on it almost every time I put the tape in. Unplugging and plugging and repeatedly pressing the eject button finally ejects the tape fully, but the other problems remain.
I have a TRV 120 that keeps kicking out each tape I put in it. It stays closed for a second and then ejects the tape. The code on the screen is: C31 10 meaning that a malfunction has occured that you can service! Any ideas?
Posted on Sep 05, 2009
From the user manual ...
Under self diagnosis display
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Posted on Jun 14, 2009
Whenever I insert a new video tape on my Sony Handyman DCR-TRV120, it says "C:31:23" and it tells me to eject the tape. Once I take out the video tape, it rather has the film outside of the tape,...
You have a transport problem with the tape feed. If you are up to working in small spaces without damaging adjacent parts, you can try and clean the pinch roller and capstan drive system with alcohol on a Q-tip. Sometimes, there are special cleaning tapes your can purchase that will do the same thing. Assuming that the transport is dirty, you may have a shot at it. If it's excessive wear instead, it's shop time. One more thing. DO NOT USE A CRINKLED TAPE IN YOUR CAMERA. IT WILL TEAR UP THE VERY DELICATE TAPE HEADS PERMANENTLY.
Feb 04, 2011 | Sony Handycam DCR-TRV19 Mini DV Digital...
I was capturing a tape and got a flashing C32:21 message and lots of beeping. I stopped the camera and tried to eject the tape but the carriage is halfway up and won't go up or down now. Any...
I'm sorry that the camcorder display the error: C32:21. Refer the URL to troubleshoot the issue:
The error C:32:xx indicates that the camcorder has detected an issue that may require a power reset. Follow the steps to perform power reset:
Turn off the camcorder.Remove the battery or disconnect the AC power adapter for 60 seconds.Insert the battery or reconnect the AC adapter.
Dec 23, 2010 | Sony Handycam DCR-TRV520 Digital Camcorder
What would cause a sony dcr trv120 zoom button not
There is control switch block that has zoom/wide switch along with play, rewind, forward, stop, pause buttons and this switch block flip up and down while ejecting/ load tape in camcorder, this will be replaced as zoom/wide switch got defective and sending continues command of zoom to system control chip.
Let me know if you need part number of switch block control for DCR-TRV120
Jul 27, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
Tape will not load; Error code 31:23
You may try the following troubleshooting steps:
Remove the battery of the Camcorder for one minute and re-insert the battery to check whether it works.
You may try resetting the Camcorder by pressing the RESET button located on it.
You may also check whether the issue occurs for all the tapes.
If the issue occurs with all the Tapes then it seems that internal parts of the Camcorder are malfunctioning.
Hence, the Camcorder requires service.
Jul 14, 2010 | Sony Handycam DCR-PC1000 Mini DV Digital...
I have a Sony PDX-10 and it's giving me two blinking yellow symbols (underlinded triangle and tape with line through it) when I fire it up loaded with a tape. Tried changing with tapes that work fine in...
Looking at PDX 10 User Manual Page 232
Your description -
Under lined Triangle
Cassette Ejection needed
Slow Flashing: The Write protect tab exposed
Fast Flashing: Moisture Condensation
Cassette out of tape
Self diagnosis display function activated
Sounds like the diagnosis function maybe your best shot......
Check displayed error codes in viewfinder on Page 231 of the User Manual or let me know if you dont have copy of them.
Tape Symbol Flashing:
Tape near end
No cassette inserted
The write protect tab exposed.
I think this is basically telling you the loading mechanism has a problem, the viewfinder is displaying an error code indicating the nature of the fault..... IF error Code is : E61:........ or E62........ (dots indicate extra numbers) these MUST be referred to Sony Service Centre.
Hope this may help
Ian 561
Jun 24, 2010 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
I have a Sony CCD-TRV308 NTSC that flashes the following fault codes: C:31:40, C:31:22 and C:31:23. I have repeatedly removed the tape and the battery in an attempt to clear this. It will run for a few...
The 4-digit error code consisting of an alphabet and numbers, which blinks at 3.2 Hz is dislayed on the screen when any problems occur. This 5-character display indicates the "repaired by:", "block" in which the problem occurred, and "detailed code" of the problem.
The error code C:31:22 and C:31:23 indicates T reel fault and S reel fault respectively. Load the tape again, and perform operations from the beginning.
The error code C:31:40 indicates FG fault when starting drum. Load the tape again, and perform operations from the beginning.
Furthermore, press and hold the power button for 30 seconds then try using the Camcorder.
If the issue persists then service is required.
Sep 17, 2009 | Sony Handycam CCD-TRV308 Camcorder
Code: 31:23....please reinsert tape. everytime i switch it on.
u need to rate me for that ..ok dude....
actually this error is related to s reel i.e, the supply reel of the camcorder and some time when we insert a new tape in camcorder it start giving the error because the amount of tension is more in new tapes as compared to the old ones (used one) . . try to use the old tape u would nt have any problem .
but with new tape u will have these kinds of problem some times , to solve this problem for new tape u need to take the camcorder to near by service center of sony .nd they will align the tape path of your camcorder .
Jun 22, 2009 | Sony Handycam DCR-TRV265E Digital...
PC101E - Dew Sensor flashes up when I switch on the camera
rub the dew sensor with q-tip & alcohol and the condensation warning should disappear!
Mar 18, 2009 | Sony Handycam DCR-PC101E Mini DV Digital...
You need your CAM into Sony or service center Sony to repair it the error code is indicated the LS chassis assembly faulty or loading motor faulty it require a lot of work mechanis and electronics it may not worth to repair it. It would cost between $150 to $250 in AUS
Oct 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Sony dcr-trv120 playback
the problem is with the video head. either it's dirty or broken. if cleaning tape is not solving the problem then i fear you have to get the head changed. an expensive repair.
Jan 18, 2008 | Video Cameras
Sony Handycam DCR-TRV120BT Digital Camcorder Logo
583 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
