Just had a flat screen plasma installed in our office. When it is powered from the outlet the screen rolls. When it is powered from a small UPS it stops rolling. The electrician said that it is not his problem.
    Genius:
  • 2,920 Answers
Hes right its not...whoever wired the building is responsible for the wiring, he did his job installing the tv where you plug it in is up to you
Posted on Dec 06, 2008
    President:
  • 2,992 Answers
It sounds like you have some piece of equipment in your office that is radiating AC interference back into the power line. The UPS would act like a filter to clean it up, but the set's power supply is affected when you power it directly from the line. One option is simply to leave the UPS there for the TV. Another option would be to try to determine where the interference in coming from. Find out what other equipment is on the same circuit as the TV and shut each item off one at a time until you see the TV clear up.
Which are the surge protected outlets on a cyperpower 1000AVR?
The surge protected outlets should be identified on the top of the unit. If not identified, all outlets may have surge protection.
Jan 27, 2015 | CyberPower Cyber Power OFFICE POWER AVR...
Panasonic Viera plasma suddenly shut off and wont turn back on and when off it has a dark line on screen
Try disconnecting all HDMI cables and plugging the TV into a new wall outlet. If the issue is resolved, it may have been caused by a small power surge from either your wall outlet or one of your source devices.
Nov 13, 2013 | Panasonic Viera TH-50PZ800U Plasma TV
APC will not stop making noise even after I
Disconnect the battery(s) from inside. The backup batteries are still working...
Mar 12, 2010 | APC Back-UPS Office 500VA (BF500) UPS...
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
NO POWER ON THE TV SANSUI PLASMA SV EPD 4230BP .IT HAS TRIPPED THE ELECTRICITY.NOW THERE IS NO POWER ON THE PLASMA TV WHICH IS 42 INCH.
If you have a power cut when tv is on - it shuts down for safety - leave it for 1 hr or overnight - then it works!! I have a UPS as our power here in Mozambique always goes out
Aug 12, 2009 | Televison & Video
Advanced power options settings UPS for blackout buster?software
I have to answer this question with just plain old common sense. Get a new one! This is crazy. If you get a new one, you will have a better, more upto date and something you can handle with todays OS and obviously new batteries. That is too old to mess with. I fixed a powerware once and the plastic was falling apart and the PC board was held together with a rubber band. Not worth it.
Jun 03, 2009 | PK Nextgrid BlackoutBuster B6U2 UPS System
Lost microsoft office
Insert the office discs and select the repair option from the startup screen. This will overwrite any corrupted files and registry settings.
If this doesn't work you can do a complete reinstall by uninstalling in add remove programs and restarting your computer then reinstalling office. This wont affect any of your documents and will replace your office files.
Dec 30, 2008 | Microsoft Internet Office 750VA UPS Backup...
My client has 19" in rack mount ups's circa 3kW. The building has generator back up however when we drop the mains and put the building on generator the ups do not see the generator hence stay on...
It sounds like someone wired your outlets wrong. I actually just found the same exact thing in my server room. All other outlets in our office are covered by our generator backup power except our server racks. I would suggest contacting the original electrician that installed the wiring to come out and check it again. Something is clearly wired wrong.
Dec 21, 2008 | APC Smart-UPS RT 1000VA (SURT1000XLI) UPS...
ONLY 2 MINUTES MAX OF BATTERY BACK-UP TIME BEFORE EVERYTHING SHUT
you can program your power bottom to hibernate, and connect the screen direct without the UPS, so you get more time...then when the electricity goes off, without seeing the screen just push the power bottom to hibernate.
Dec 03, 2008 | Minuteman Office Plus 500 UPS System
Flickering of Panasonic Plasma
hello, you may need to get yourself a power line conditioner or a ups "uniteruptable power suppy" and plug your tv to ups plug the ups unit to your power source, seems your wiring is shared or distributed to the kitchen and possibly other rooms.or you may have some bad wiring or imporperly grounded distribution of the power from your main fuse box
you can also have someone instal a dedicated fused line for the tv alone this may help good luck
Nov 30, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
