Question about Conair FSP5 Iron
I have the conair fsp5 fabric steam press, i filled the water tank,put the dial on steam,am i suppose to actually see the steam ??? or hear it as it presses? cause i dont
  • Dianna Ritchie May 11, 2010
    How did you fill the water tank? I just bought one at a garage sale, and can't figure out how to fill it with water for steam ironing. I see the plastic container but can't get it out. If I could get water into it I could answer your question.
5 Suggested Answers
  • 50 Answers
SOURCE: how do you fill the water tank on the steamer
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Posted on Jun 04, 2009
  • 38 Answers
SOURCE: CGS11DR CONAIR GARMENT STEAMER
Have you checked the float?
Sometimes that gets stuck, or collects mineral and stays in the last position.
Matt
Posted on Sep 14, 2009
SOURCE: I have a GS60 conair
I had the same issue. You can visit the Conair website for a PDF of the manuel.
http://www.conair.com/instruction_booklets/06PC2363%20gs60%20IB.pdf
Posted on Sep 05, 2010
  • 1179 Answers
SOURCE: Need a water tank for a Conair FSP5 Fabrix Steam Presser. know where I may find one.
Phone number is on page one
http://www.conair.com/instruction_booklets/FSP5%20rev%20IB.pdf
Posted on May 14, 2015
Water tank reservoir for steam presser FSP5
Contact the manufacturer of the appliance for parts, if it is available they will be the only one tat will have it.
Nov 29, 2016 | Irons
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
My GS23R fabric steamer does not work.
Time to return under warranty. There are no user serviceable parts.
Nov 06, 2014 | Conair GS33R Compact Fabric Garment...
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
I bought a Durabrand TSK-7538S Steam Iron for $12 at Wal-Mart. It's fine but the "instructions" are poor. I can't figure out how to set the temperature. I mean, I know you turn the dial, but...
okay. thats not a bad question, i got the same iron, and i know what your're talking about. the "line" you're talking about is not a line at all, it's actually a tiny plastic indicater at the bottom of the dial. it's blue too, so you cant see it, so feel on it with your finger. =) email me if i helped. solacewishes@yahoo.com
Apr 21, 2008 | Conair Compact Garment Steamer Iron
Conair FSP5 Iron Logo
101 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
