IBM Sel. II will not power up
The last time I was able to use my typewriter it started
acting mean and made rather loud sounds and then
suddenly died.
  • Tinkerbelle1 Dec 07, 2008
    Jim, All I needed was a lead - Ed thinks he can take a
    look at that. I found what seems like a well run
    company in downtown Atlanta. Thanks a bunch.
  • 475 Answers
It sounds lika the motor belt broke not an eazy fix see a typewriter repair person
Posted on Dec 07, 2008
How can i repair an ibm wheelwriter 50 typewriter
Unfortunately your machine may need to be serviced by a qualified technician as you may need anything from a power supply, function board or system board. Only someone who has those parts in stock may be able to swap them to see witch part os partsd are needed to repair your machine.
Aug 05, 2014 | IBM Wheelwriter 50 Series Ii 6788 Tested...
On my IBM sel. III, when I type a "/" get a "3"
Eugene, a pleasure to make your aqaintence. I spent about seven years inside the belly of the beast and your spot on. I'm going to assume you done the obvious, it's been a long time I'm 55 and the last time I touched a Selli gas was a buck-50 a gallon but it seems to me I had a cycle clutch do somthing like that It didnt happen often but your at Max pitch, does it occur at both high speed and low speed typeing, do you have a worn set screw, I was just starting to get good on them when I went full time copiers, give me a snort and let me know what you think??, brethall610@icloud.com
Jan 13, 2014 | IBM Correcting Selectric III Electric...
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
I have an IBM wheelwriter 1500. I was typing and all of a sudden the power just died, it is plugged in, I changed batteries but nothing works.
Doesn't sound good. Try a known good outlet. You may need a power supply or processor board either part is about 125.00 plus installation.
DickyO
Jun 07, 2011 | IBM Office Equipment & Supplies
I have a couple of IBM Selectric II Typewriters and over the last few months both just quit as if they are getting no power. One started working again but then quit again..any ideas on how to fix. Also had...
Most selectrics at this time are suffering from many gummy parts.
All of these problems are probably repairable with a good chemical cleaning and lube.
DickyO
Dec 11, 2009 | IBM Office Equipment & Supplies
Typewriter only beeps and lights blink. Nothing else.
the beeping and the lights are error codes, meaning the machine will need repair
Feb 25, 2009 | Lexmark Wheelwriter 30 Series II...
IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
DickyO
Feb 14, 2009 | IBM Office Equipment & Supplies
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
jasbo
jasbo
