Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
SanDisk 2GB Cruzer Micro - Not Working I have a Dell Insperon 1501 Laptop; and for the past year and a half I have been using three SanDisk 2GB Cruzer Micros for file storage. As I do everytime I use the USB, I safely removed the SanDisk Cruzer Micro earlier this morning then, when I went to use it again this afternoon it did not register in My Computer or light up - I tried it in all 4 ports, to no avail. I used my other two SanDisk Cruzer Micros and tried them both in all four ports and they worked in each port. What is wrong with this paticular SanDisk 2GB Cruzer Micro? Why was it working just fine earlier and now it is not regersting? Will I be able to get it to work again if not, will I be able to recover the files from it? I have been searching the web all night, and so far to no avail. I apperishate your time and help! Frusterated SanDisk 2GB Cruzer Micro user in Utah...
    Genius:
  • 1,061 Answers
There are problems similar to yours with this unit try here read and decide if you want the data recovered.http://datacent.com/datarecovery/hdd/usb_flash_key/Sandisk+Cruzer+Enterprise+2GB.RICHARDM69
Posted on Dec 06, 2008
  • Desktopsbyduck-Computers
    There are problems similar to yours with this unit try here read and decide if you want the data recoveredhttp://datacent.com/datarecovery/hdd/usb...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem indicate a possible hardware issue. There are only 4 terminals/pins ina SUB device. The two at extreme ends are for GND and B+5 while the two at the middle are for DAT+/-. For your particular concern, you would be interested with the two terminals/pins at the ends especially Pin#1 which is the Vcc (+5). You would need a continuity tester to determine if there is contact, meaning does the pin still connect to the electronics internally of the SanDisk 2GB Cruzer Micro. Of course the thumb/flash drive must be opened up to expose the PCB.
In most instances it would only be a cold solder or a loose connection and re-application of a soldering iron should do the trick. Might as well do cleaning of the 4 pins. A flattened cotton buds would do or better yet scrape the terminals a bit to remove corrosion.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 2,326 Answers
I'm afraid that the scandisk might have become corrupted or the hardware inside has failed and that is why the computers are not registering or recognizing it.
If that is the case, the information inside the scandisk is gone, unless you can de-solder the memory IC from it and install it on another identical scandisk.
  • Jaime Hernandez Dec 06, 2008
    Does the computer recognize it when you plug it in?
Sandisk 2gb cruzer micro usb broke
if the usb connector broke off of the board inside the plastic casing, no, you wont be able to retrieve the data.
May 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer isn't working after a while
Hi
Thank you for your query
If you have tried it in multiple machines then unfortunatley the pen driver has burnt out. This is not to uncommon, Sandisk pen drives do come with a 5 year or a lifetime warranty, so please contact them for a replacement/refund
I hope this has been useful
Feb 28, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a compac vista laptop and am trying to download pics on my sandisk cruzer micro 2gb Any instructions available?
All you have to do is drag the pictures off your computer onto the cruzer drive. You can treat it just like a 2nd harddrive.
Oct 11, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Instructions on how to upload a powerpint
Hi...
What did you mean, if you want to save power point in you Sandisk, it is not upload it is only save. you can save this true copying files form your computer, then paste it to your sandisk folder.
Regards
PCmania
Jul 11, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
1 gb cruzer dosnt not work
I used 1gb cruzer for 1 year and it stop working today, it does not detect computer, its flash light and it emerged after fews seconds.
Erjok Kuol Deng
Sep 20, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Scandisk Cruzer micro 1.0 problem - three blinks, three blinks, etc
It means a problem in vista
I'll post if I find the solution , working on it right now
the good news is , it's not broken , it's just vista being a pain.
Aug 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Do you have SP2 on your computers....? and is there any error that is shown whenthe USB drive is inserted into your computer?
Apr 14, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer micro flashdrive - not working on vista
you'll need to go to the sandisk site, and get a vista driver set..
Mar 11, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Micro Cruzer reduced from 2.0 GB to 1.0 MB when reformated
Make sure you check to see if the File System is FAT32 instead of FAT or NTFS, this way you can have your 2GB back.
Try reformatting using FAT32.
Dec 10, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
70 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
