Question about Vtech LS6115-2 Twin - - Phone
My incoming calls can not hear me. I can hear them
I try to hit the mute button while I am on the line, and the microphone on display shows but I am still not heard. This is with both handset and this is a brand new phone. Please help
  • Anonymous Jan 16, 2009
    i have the same issue with one of 3 handsets
SOURCE: My VT 2421 LCD display "B53"
Is this a second hand set? If so you need to sync it with the base to use it every time it loses power from the batteries. Put it on the main base for 30m seconds and try it again.
Posted on Jun 27, 2007
SOURCE: Every handset is showing me connecting ...
I am having the same problem. I unplugged everything, and nothing changed. Phone #2 comes back sporadically. Has anyone gotten word from Vtech?
Posted on Jul 11, 2008
SOURCE: The other party cannot hear me from one of the Uniden DCX 640 handset
don't hear with uniden 640 dcx
Posted on Nov 07, 2008
bunnydawg
  • 5158 Answers
SOURCE: I have a vtech 5.8ghs
Reset the phone by unplugging BOTH the adaptor and the phone line (the phone gets some power from the phone line). after you have done that put each hand set into the main base till the lite flickers (not the charging stand)... phone should be good to go after that
Posted on Mar 16, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
When I get incoming calls I cannot hear
In order to make calls, Microphone access is required. If you check your Microphone settings and see that they are just fine, try plugging in a headset with a mic on it. If you don't have that, try checking the mute switch next to the volume buttons, or the mute button in the call screen.
Apr 07, 2015 | Apple iPhone 5c
Microphone not working
Make sure that you did not accidentally hit the mute button on your phone. I do it all the time with my cheek.
Jan 18, 2015 | Cell Phones
Why when I phone some one I can hear them but they cant heat me
You may have accidentally pressed the Mute button. Undo as below
Mute a Call:
You can talk to someone nearby without letting the caller hear you during a call. During a call: Press <C> t o mute the microphone and "MUTED" will display on the LCD.
Your caller cannot hear you. Press <C> again to unmute the microphone.
Nov 19, 2014 | Binatone Lifestyle 1910 Twin Cordless...
When making or recieving a call, i cannot hear the caller but they can hear me. the volume is up so i dont no what the problem is
Your phone is either muted on your end or the microphone has gone out on it. Next time you're in a call look in your call options and see if there is a mute option, or see if there is a microphone symbol with a line through it on your call screen. If there is a microphone symbol with a line through it click it to turn the mute off. If you don't have a mute option on your phone then chances are the microphone has gone bad.
May 03, 2011 | Samsung Solid B2100 Cell Phone
So basically, i tried webcamming my friend thats in Germany, and she couldnt hear me, and i tried testing on my skype test call thing, and they said that my microphone on my laptop might be muted. I have...
go to Tools => Options => Audio Settings, see Microphone Volume, uncheck Automatically adjust microphone settings, adjust volume manually, test mic if green line showing up. To check if mic is muted, when calling contact in the calling window point on mic if it says Unmute microphone click on it, if it says Mute microphone it's already unmuted.
Oct 21, 2009 | HP Mini 1000 Notebook
Microphone does not work
Hi
with referance to your problem it seems like it can be look in two ways , first by software and then by Hardware ,
First Check if microphone is not muted inside from the phone , means in its software ,
Then below is the picture where you can find the blue box shows that their is button for microphone to turn on / off during calls,
If these steps not help then , it meght be possible your microphone is defective and you have to change your microphone.
Kindly Rate !
Sep 05, 2009 | RIM BlackBerry 8700g Smartphone
Remove message of the middle line of display
Pick a spare button and label it CALL LOG. Now press PROG that button and dial 54 STORE. Ooh, it should light up. Now press it and your display will show 3 of the 4 lines of CID info from the calls to your set. The navigator button will show the rest, just keep pressing the UP, DOWN, LEFT, RIGHT buttons. When you run out of items to display, the light and INCOMING CALL display will go out.
If you press 54 and the 3 digit number of your incoming call group (maybe 601 by default) it will follow the incoming calls to the entire call group.
Carl
Apr 24, 2009 | Panasonic KX-T7630 Corded Phone
"Incoming Only"
depends what model phone it is, try Feature * 2 then press the button you want to program, this will show what that is currently used for
Jun 25, 2008 | Nortel Norstar 16-Line PBX Speakerphone
LG CU500 cell phone
hit the button on the side that you use to change your volume untill it goes to the section with the blue bars then hit the cingular guy button
Jun 08, 2008 | LG CU500 Cellular Phone
Cannot hear incoming call or caller cannot hear me
First check and adjust call volume. It should set be optimal and secondly during a call adjust the microphone volume. If this is ok and the problem exsist then the microphone, speaker or some other hardware need to be replaced. Contact local hardware expert.
Aug 25, 2007 | Palm Treo 650 Handheld
Vtech LS6115-2 Twin - - Phone Logo
27 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
