Question about NetGear WGT624 Wireless Router
Wireless connection I have a netgear WGT624 router connects to internet perfectly but my acer laptop will not connect up on the wireless network gets a great signal but just cannot get it to connect (wep is disabled) any ideas? P.S. my other pc connects fine on wireless network
  • Anonymous Feb 23, 2008
    acer wont coect to wireless laptop
  • 3 Answers
NETGEAR Technical Support Engineer 1. access 1st the router's setup page * open up a browser * http://192.168.1.1 or http://www.routerlogin.com/ 2. go to wireless settings under setup if you have a wireless phone at home change the channel of the router, make sure they dont have same channel 3. change the mode of the router to w/c your laptop's wireless adapter support (eg. b only, g only ) 4. try to change security option wpa instead of wep (make sure your laptop's adapter support it) 5. change SSID (note: if you've change the SSID of the router, remove the profile on your computer under preferred networks 6. change your passphrase 7. Disable Advanced 108Mbps Features 8. Disable Setup Access List (it can be found in wireless settings under advance) 9. upgrade firmware of the router * before upgrading make sure you backup the settings (go to backup under maintenance) * if latest firmware is installed * flush firmware (flushing it is just reinstalling even if the latest firmware is installed) 10. power cycle frequently (turn off for 10 seconds then turn it on again) 11. If all of these didnt work call your laptop manufacturer for help 12. call gearhead -> 1-888-615-3488 13. or call our technical support 1-888-netgear lucky if you got me ***caesar *** NETGEAR technical support engineer
Posted on Mar 17, 2007
When I look at the activity in the wireless network connection status window, the received # is 0! Why and how do i fix it?
Posted on Mar 29, 2008
Make sure that your laptop wireless NIC card is plugged in correctly (double check by removing and reinserting, you may have a little difficulty when removing the arial connectors just be careful and use a small flat head screwdriver), I say this as I had bacicaly the same problem with a dell laptop and a 3com wireless access point.
Posted on Mar 18, 2007
    Scholar:
  • 113 Answers
If 'obtain an ip address automatically' is enabled, check the IP Address (Go to the command prompt - Start -> Run -> cmd; in the command prompt type 'ipconfig'). If we have a valid IP Address - something in the range of 192.168.1.x, attempt to ping the router (Go to the command prompt - Start -> Run -> cmd; in the command prompt type 'ping 192.168.1.1'). A successul ping would mean we have a successful connection between the router and the laptop. Attempt pinging certain websites thereafter. If the ping is unsuccessful, look for any active software firewall. Disable the firewall and try pinging again. You haven't specified the ISP and the make / model of the modem. Also, check the IP Address on the PC which is able to go online.
Posted on Feb 13, 2007
    President:
  • 2,961 Answers
Right click on your wireless connection in taskbar and click on open network connectons, right click on your wireless network connection and go down to properties. On the general tab click on tcp/ip and click properties, then make sure obtain IP Address automatically is enabled. If you still cannot connect, try this:- ipconfig /flushdns then press enter.(note the gap between ipconfig and the /).
How can i connect my iphone to my wireless network when i forgot the password! i have netgear wgt624, i tried "password" no joy
you can access the router's wireless settins so that you can check the wireless password or the network key for you to connect your iphone to the internet
Jul 24, 2010 | NetGear WGT624 Wireless Router
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
Why does my WGT624 keep loosing connection. I would be on the Internet and for some reason, I would loose connection to the Internet. I have a Dell Inspiron...1521 computer.
In my case too this happened initially with my lenovo y410 laptop with netgeat router. In laptops if th ewireless network is set with "public" profile then the connection is sometimes dropped by the driver. If you or only a few persons are the only user(s) of your router and your WLAN is securely encrypted, then you can change the wireless settings of your laptop to be in "private" network, which will solve your problem.
Oct 31, 2009 | NetGear WGT624 Wireless Router
What steps do I take to allow my 2nd computer, a laptop, wireless connection to internet through my WGT624 wireless router?
>Switch on your laptop wireless..
>Goto Network sharing center from network connection settings menu from control panel..
>Search for New Connection and select your Wifi router And mark it as shared..
Aug 14, 2009 | NetGear WGT624 Wireless Router
Wirless network - laptop
See what ip,gateway and DNS its getting from the access point.If its getting the right ips then your network should work. If it is not getting the right ips then there must be some problem in the DHCP configuration of the access point
Jun 25, 2009 | NetGear WGT624 Wireless Router
Netgear wgt624 with WGt111 usb wireless connection showing red no connection when using netgear wizard programme
Follow the steps to configure wireless connection :
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connect
Jun 08, 2009 | NetGear WGT624 Wireless Router
Netgear WGT624 router won't connect to the internet
I am in the UK and have found through experience the Netgear's seem to work perfect on a BT line (equivalent of AT & T)
but not on the cable.
I would suggest purchasing a Linksys by Cisco WRT54GL Wireless-G Broadband Router as these seem to install in minutes,
saves me hours of wasted time when setting up wireless networks.
Jan 18, 2009 | NetGear WGT624 Wireless Router
Wireless connection
Make sure that your computer is getting a valid IP address from the router. If your wireless network is secured, you might as well consider checking the wireless settings.
Oct 06, 2008 | NetGear WGT624 Wireless Router
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Nov 27, 2007 | NetGear WGT624 Wireless Router
Wireless network
Have you looked at these posted solutions? http://www.fixya.com/support/t133938-wireless_connection
Feb 14, 2007 | NetGear WGT624 Wireless Router
NetGear WGT624 Wireless Router Logo
206 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
